An easy way to fix stripped holes in outer fairing - Road Glide Forums
post #1 of 20 (permalink) Old 05-04-2013, 01:55 PM Thread Starter
JuicedHD's Avatar
So I was at the Home Depot looking for larger screws and epoxy so that I could repair the stripped holes in my outer fairing and ran across this item....
So I tried it and it works great. All you have to do is cut a couple of thin strips the length of the hole and place them in the hole. The screws go in tight and bring the fairing in perfect.
The best thing is that this fix cost me less than $2.00 and took less than 10 minutes. You can make this repair without removing the fairing if you have a pair of needle nose pliers for sticking the strips in through the inner fairing hole.
2009 - FLTR - SE 110, RC Componets slip-ons, Alpine/Polk/HAT/RF audio, RC Component Imperial Wheels 21/17 combo, 12” DNA Monster bars, TopShop rear fender and bags, More to come... JuicedHD...
JuicedHD is offline
post #2 of 20 (permalink) Old 05-04-2013, 03:21 PM
598Malibu's Avatar
Guess time to head to Home Depot and buy some for the inevitable.
2012 Big Blue Pearl FLTRU
72 Chevelle with Procharged 598
598Malibu is offline
post #3 of 20 (permalink) Old 05-04-2013, 04:08 PM
Wooden Nickel
Guest
Posts: n/a
Thanks, I can use one of those myself.
post #4 of 20 (permalink) Old 05-04-2013, 04:31 PM
TimMCc's Avatar
Thanks for posting. I'll keep this in mind if I run into that issue or for when I do...
Hold fast!
TimMCc is offline
post #5 of 20 (permalink) Old 05-04-2013, 08:16 PM
jack6hd's Avatar
Great post. I couldn't help but notice the "Made in USA" logo. Nice!
2015 FXDL 2nd best HD on road
jack6hd is offline
post #6 of 20 (permalink) Old 05-04-2013, 08:23 PM
How is that fix when you unscrew it later? I have been using a toothpick for years and just have to add another when doing a R&R.
Jayray is offline
post #7 of 20 (permalink) Old 05-04-2013, 10:31 PM Thread Starter
JuicedHD's Avatar
I don't know being that I just used it today. In the package there are 6 or 8 pieces and I didn't use but a third of a piece. So if I have to replace, it will not be a problem.
JuicedHD is offline
post #8 of 20 (permalink) Old 05-05-2013, 06:36 AM
Ohiobellboy's Avatar
tagged....
A.K.A OBB
Ohiobellboy is offline
post #9 of 20 (permalink) Old 05-05-2013, 07:38 AM
LPrez's Avatar
Very nice. Just last w/e was wondering how I'd resolve the issue. Voila!
LPrez is offline
post #10 of 20 (permalink) Old 05-05-2013, 06:54 PM
dknapp's Avatar
Your awesome, just stripped one today!!! Thx
dknapp is offline
Outer Fairing screw hole stripped motosig102 Paint & Bodywork Section 37 08-02-2016 10:47 PM
My fix for stripped holes on ABS plastic fairings Iridealot Do-IT-Yourself 11 03-25-2015 08:42 PM
Stripped Fairing Holes RedDogNC *General Road Glide Discussions/Pictures 12 02-02-2014 06:12 AM
Partially stripped transmission drain - best fix? HD_Shock Troubleshooting for Road Glides 18 09-09-2013 12:37 AM
Stripped holes pte359 Paint & Bodywork Section 7 08-03-2011 07:14 AM
