How to adjust neck bearing? - Road Glide Forums
  • 1 Post By 1st Sgt
post #1 of 7 (permalink) Old 12-21-2017, 02:50 PM Thread Starter
Hey I got a 2012 with a bad shake in the bars on deceleration is there a write up on how to adjust the neck bearings?
Adammarkel is offline
post #2 of 7 (permalink) Old 12-21-2017, 04:41 PM
https://www.roadglide.org/14-tech-are...ring-easy.html
Jake over at Glide Pro got some videos also.
WTTF
post #3 of 7 (permalink) Old 12-21-2017, 04:54 PM
1st Sgt's Avatar
Check the fork swing but also whats the condition of your front tire? Seems like I always get a shimmy upon deceleration when my front tire tread is coming down to the wear limit.
eddienelson likes this.
1st Sgt is offline
post #4 of 7 (permalink) Old 12-21-2017, 05:27 PM Thread Starter
Tire is almost brand new and the shake I get is pretty violent
post #5 of 7 (permalink) Old 12-22-2017, 04:08 PM
ERod62's Avatar
Not a bad DIY. Donít forget to grease the neck bearing while at it.
ERod62 is offline
post #6 of 7 (permalink) Old 12-22-2017, 06:51 PM
eddienelson's Avatar
Had the same issue on a Vmax. Brand new tires are man made and it is possible to get a bad one or have one go bad. Its gonna be either of the two. Headset or tire.
2016 RG Custom Vivid Black
eddienelson is offline
post #7 of 7 (permalink) Old 12-22-2017, 10:35 PM
Clutch1's Avatar
Iíd check tire alignment as well. Bad tire, badly aligned tires, or bad neck bearings. The neck bearings rarely go if greased regularly and you arenít pulling wheelies with hard landings.
04 RG
Clutch1 is offline
Adjust your Steering Head Bearing...easy hotrodad Tech Area 56 10-25-2013 06:43 PM
Neck bearing adjustment MyGlide Tech Area 16 02-22-2013 11:31 AM
WTF, Neck bearing Adjustment not a warranty problem?? HarleyArcher *General Road Glide Discussions/Pictures 33 07-13-2012 06:08 AM
New tire, Neck Bearing adjusted twice - Now what? RTWRK *General Road Glide Discussions/Pictures 17 01-02-2012 09:02 AM
shifting and neck bearing BklynRGU Road Glide Specific Discussions 5 05-12-2011 11:00 AM
