Having trouble adjusting neck bearing - Road Glide Forums
post #1 of 4 (permalink) Old 01-01-2018, 02:21 PM Thread Starter
Ok I got the pinch bolts loose and the stem nut loose and I made a couple tools for the adjustment nut but it wonít turn I know itís loose since I can move the washer underneath it up and down should I be able to turn the adjustment nut by hand with the tool?
Adammarkel is offline
post #2 of 4 (permalink) Old 01-01-2018, 03:32 PM
No, tap it with hammer.
https://glide-pro.com/media/
post #3 of 4 (permalink) Old 01-01-2018, 03:50 PM
skratch's Avatar
i see from your other posts that you have a 2012. having done this on a couple of my bikes, a 2010 and a 2013, i can tell you to be careful. a little bit goes a long way. just a slight tap took my fallaway from almost 4 swings to less than 2.
skratch is offline
post #4 of 4 (permalink) Old 01-01-2018, 08:32 PM
mastergunnera8's Avatar
Agree with skratch, easy as you go.....I went to Ace hardware and picked up a long piece of flat stock, bent it slightly at the 4-5 inch mark and it worked great tapping with a mallet.
Did you lift the bike up and support the front wheel when trying to tighten? has to be free to do the swing test, but supported when tightening...I used a hyd, car jack right under the tire
mastergunnera8 is offline
Anybody having trouble with there PBR300X4 shutting off? Whtlac Audio 4 11-07-2013 07:54 AM
If you're having trouble coming a lot, maybe you can come a little.... Quicksand ARCHIVES-SWIII St. George, UT 11 06-02-2013 06:51 PM
Is anyone having trouble with Bad Spark Knock? Dandy1 *General Road Glide Discussions/Pictures 66 08-24-2011 06:49 PM
