CAM Upgrade - Road Glide Forums
post #1 of 6 (permalink) Old 01-12-2018, 01:23 PM Thread Starter
CAM Upgrade
Gents, I have a 2017 RG and would like to upgrade the cam. Do I have to upgrade the Cam Plate and Oil Pump as well?
ace8599 is offline
post #2 of 6 (permalink) Old 01-12-2018, 08:39 PM
Clutch1's Avatar
If I was going in there, Id put a fueling cam plate and high output oil pump for sure. Worth every penny in reliability and longevity.
04 RG
Clutch1 is offline
post #3 of 6 (permalink) Old 01-12-2018, 09:12 PM
lil chief's Avatar
Do you have to change them? No. Theres nothing wrong with the stock set up. If you're planning on buliding the motor into a beast, then maybe I'd do it.
If you want to change it out for an aftermarket or SE, go for it, but it's not necessary. I'd spend the money on some good quality lifters to go along with the cam swap instead.
Lil Chief
lil chief is offline
post #4 of 6 (permalink) Old 01-12-2018, 11:29 PM Thread Starter
Sounds good to me.. Thanks
ace8599 is offline
post #5 of 6 (permalink) Old 01-12-2018, 11:30 PM Thread Starter
That make sense.. Thanks
ace8599 is offline
post #6 of 6 (permalink) Old 06-10-2018, 10:20 PM
D.Candel's Avatar
If there’s any sign of scoring on the cam plate it should be replaced. If you’re keeping the stock oil pump, make sure it’s the latest part number. (They’ve changed like 4 times)
Replace the inner cam bearing with an SE one. (Cam bearing remover and installer needed)
The torque procedure on the manual is not the correct one. (A service bulletin has been out with the correct procedure)
I’m going with Feuling whenever I decide to do it.
D.Candel is offline
Cam suggestions for 2000 also cam chain tensioner upgrade dirtracer27x Engine Related 22 04-09-2014 07:47 AM
Cam upgrade... Need some advice NTEXRG Engine Related 9 04-16-2012 09:10 AM
Cam/engine upgrade... ZachB Engine Related 10 04-04-2012 01:12 PM
Cam upgrade craigv65 Engine Related 12 01-30-2012 07:26 AM
screamin eagle cam plate upgrade fredflintstone Engine Related 6 01-01-2011 11:19 AM
