Bars still shake on deceleration - Road Glide Forums
 2Likes
post #1 of 31 (permalink) Old 01-21-2018, 06:16 PM Thread Starter
Ok I finally got my neck bearings adjusted and greased and I set both tires psi at 38psi went out for a test ride and when you take your hands off the bars on deceleration they shake pretty violently. Where should I look next? Thanks for any help!
Adammarkel is offline
post #2 of 31 (permalink) Old 01-21-2018, 06:23 PM
norm9278's Avatar
I'd check for "hot spots" on the brake rotors, and tire balance, tread cupping, etc.
norm9278 is offline
post #3 of 31 (permalink) Old 01-21-2018, 06:29 PM
1st Sgt's Avatar
How many miles on the front tire?
1st Sgt is offline
post #4 of 31 (permalink) Old 01-21-2018, 07:43 PM
lil chief's Avatar
As stated, check the condition of your tires first. If they are in good shape it's possible that you maybe lost some wheel weights, throwing the wheel out of balance. Could also be a loose motor mount or heim joint on top of the motor, but you'll generally see the motor bouncing around a bit more than usual at idle if its mounts.
Lil Chief
lil chief is offline
post #5 of 31 (permalink) Old 01-21-2018, 08:05 PM
RonC26's Avatar
Donít know what year bike you have, but my 13 used to do this intermittently. Always made sure I had 36 front and 41 lbs rear. And sounds crazy but Iíd make sure I didnít have one side loaded heavier than the other.
ďA ship in harbor is safe, but thatís not what ships are built forĒ - John A Shedd
RonC26 is offline
post #6 of 31 (permalink) Old 01-21-2018, 08:33 PM
BH#103's Avatar
Check the front tire for sure and you will want to check it cold and after you ride it. Had the stock tire on my '12 that shifted a belt. It would get worse the more you rode (warmer) it.
"SLIVER"
BH#103 is offline
post #7 of 31 (permalink) Old 01-21-2018, 09:16 PM
Bbally's Avatar
What tires are you running. How many miles on them?
USMC 79-85
Bbally is offline
post #8 of 31 (permalink) Old 01-22-2018, 06:18 AM Thread Starter
Bike is a 2012 I bought in 2017 with almost brand new metzeler tires already on it so Iím not sure if it had this problem before they where replaced. Maybe they are out of balance?
post #9 of 31 (permalink) Old 01-22-2018, 07:02 AM
Bbally's Avatar
No, but there are a bunch of tire wear patterns that once started get worse
I cannot run Dunlops stock on mine but elites are fine.
And different tires started it at different wear mileage.
Sent from my SAMSUNG-SM-G891A using Tapatalk
USMC 79-85
Bbally is offline
post #10 of 31 (permalink) Old 01-22-2018, 08:24 AM
Youíre not finished adjusting (or replacing) the neck bearings.
Some folks seek the comfort of the straight and narrow. Me? I prefer the twisted road.
RoadTrip is offline
accelleration and deceleration slack somewhere waynemags Engine Related 12 10-27-2016 09:15 PM
Deceleration wobble djsadecki Tech Area 13 04-15-2016 09:58 AM
Engine "shudder" during deceleration shock513 Road Glide Specific Discussions 8 09-26-2011 09:43 PM
Deceleration Head Shake Gone spraypilot *General Road Glide Discussions/Pictures 0 02-20-2011 07:32 PM
chirping noise on deceleration cballjr54 Troubleshooting for Road Glides 13 10-21-2010 07:46 PM
