Heated Grip Install!! HELP ME!!! - Road Glide Forums
post #1 of 3 (permalink) Old 05-12-2013, 05:53 PM Thread Starter
Hello,
I am in the process of changing out my bars and are trying to put on a set of HD Rumble Collection heated grips on my 09' CVO Road Glide. I cannot see anywhere that there is a harness to plug these grips into in the front fairing. Any help would greatly be appreciated. The wire off the left side of the bars has three wires coming off of it, and I cannot find any 3 wire connection.
Thanks,
1BadGlide
1BadGlide is offline
post #2 of 3 (permalink) Old 05-12-2013, 06:20 PM
A plug from left plugs into the rights side. A power & ground come from left & tap in at the cig lighter. It's been a few months but I think that's how it went. Good luck.
12 RGU Ember Red Sunglow
Heated Hammock seat, CVO bars
Decat, heated grips
billy t is offline
post #3 of 3 (permalink) Old 05-12-2013, 06:58 PM
eme56's Avatar
For the three wires, red should go to the battery or a constant power source, orange/white to an ignition/accessory source for power on/off with the bike, and the black one to a good ground. I have a PDF file of the instructions that came with my grips if you want it.
2005 FLTRI Black Cherry, 95" Big Bore, Thundermax w/Auto Tune, V&H Dresser Duals w/Klock Werks SS, Andrews 26 Cams, SE Stage 1 intake, SE OD/6 Speed, Wards FCS cooling fans, Krome Werks Stretch Heritage +2 bars, Progressive Monotubes, 444's, & Touring Link, Michelin Commander II's, 14.5" Madstad, Lowers with Classic Motorcycle Vents, detachable King Tour Pack, Daymakers
eme56 is offline
HD Heated Grip Install on 2015 RG (with pictures) michigander Do-IT-Yourself 39 11-22-2018 05:34 AM
2017 Heated Grip Install rdm197apd Controls & Handlebars 32 10-16-2017 02:25 PM
2017 Heated grip install question? ashnic Controls & Handlebars 3 05-01-2017 02:29 AM
Heated Grip Help theandyman Troubleshooting for Road Glides 4 06-07-2011 11:50 PM
Heated Grip install. 488pipefitter Aftermarket Accessories 3 06-04-2011 07:01 PM
