Wiring a RT Zumo 660 to an '09 RG? - Road Glide Forums
post #1 of 5 (permalink) Old 05-20-2013, 09:01 PM Thread Starter
BlkCloud's Avatar
I'm trying to wire my RT Zumo 660 to my '09 RG. The H-D instruction sheet for the Zumo (-J04901) has no information on wiring the unit to the bike. H-D's handlebar mount instructions (-J05415) aren't much better (IMO). I'm using an Iron Aces' standard mount. I'd like to connect it to the ACC plug as described in several threads in these forums. I'm looking for photo's of how to route the harness and what to do with the three plugs on the harness. Based upon the audio cable supplied in the kit, I'm guessing that it goes from the port on the side of the unit into the AUX port on the face of the radio? Any help or suggestions on where to get pics would be great. Thanks.
BTW, the Iron Aces' mount was easy to install! They did a GREAT job detailing and photo documenting the entire installation! Hopefully H-D will follow suit with future install guides.
-Chucky.
2009 FLTR Dark Blue Pearl
BlkCloud is offline
post #2 of 5 (permalink) Old 05-21-2013, 10:33 PM
I hardwired mine direct to my battery. I removed my gas tank and seat and connected it to the battery terminals. VERY simple. I also used the Iron Aces mount and have the 660. I have a 2011 RGU and have the service manual that goes over how to remove the tank. I'd be happy to scan the tank removal pages and email them to you if you would like.
Minivend is offline
post #3 of 5 (permalink) Old 06-02-2013, 06:28 PM Thread Starter
BlkCloud's Avatar
Thanks. I have both the service manual and parts manual for my year, so I'm good there. I wound up buying a power-point from Iron Aces and used that to tie into the accessory connector under the seat. I too removed the tank and ran the wiring through the track. Where I'm stuck now is; I can't get the instrument bezel to line up on the nacelle. If I don't insert the lower tab, the screws line up perfectly. When I insert the lower tab as directed, I can't get the screws to line up. Everything looks flush and even, but the screws are a no-go. Any ideas?
-Chucky.
BlkCloud is offline
post #4 of 5 (permalink) Old 06-02-2013, 06:51 PM
Govdog76's Avatar
The plastic used for the faring and nacelle are very flexible and will not crack or break. Just deform the part with your hands as needed to get things lined up. Also of course make sure that all the wires are tucked away inside there as compactly as possible.
I once saw the service writer at my dealer literally bend the top of the inner faring (with the outer removed) almost in half on itself and it just snapped back with no issue at all. That plastic is really tough stuff..
Good luck
Ian
Govdog76 is offline
post #5 of 5 (permalink) Old 06-03-2013, 10:11 AM Thread Starter
BlkCloud's Avatar
I'm not as concerned about breaking the plastic nacelle as I am stripping the plastics screw tabs on the nacelle. I made that blunder on a softail frame once when reinstalling the seat; major oops. I will keep trying.
-Chucky.
BlkCloud is offline
2011 FLTRUSE with RT 660. Want to add 665 with XM Puck DAP525 Audio 3 06-04-2014 05:49 AM
Wish I new the real story? GPS Zumo vs RT DennisT Equipment-RG 3 07-28-2013 04:49 PM
Ebitts and Sonora Passes (rt 4 and rt 108) Gonekat Road Trip Discussions/Stories/Pictures 5 06-25-2013 02:24 PM
Garmin Zumo 660 RT wired up..... SEUGOT1 Aftermarket Accessories 10 04-03-2012 09:15 PM
2011 RG CVO Zumo 660 Phone Intergration stewarrd Troubleshooting for Road Glides 26 06-18-2011 09:48 PM
