Overlay fender led light question - Road Glide Forums
post #1 of 2 (permalink) Old 04-15-2018, 03:35 PM Thread Starter
Hi I recently bought a 5” stretched bag and fender set up. I have it all painted and put together. But I am unsure of how to hook up he wiring. I’m using led strip tail light and turn signal light setup that came with the setup I bought. I have 3 wires coming from each light. Red, black, and a whitish/pinkish wire. And then I would have my two wires for my new license plate led bracket also. I’m goin to enclose a couple pictures. First of the lights and wires. Then the factory light harness. Then of the factory module or what you would call it. Not sure if I can splice and wire direct or if I need to cut plugs off the factory lights and splice hem together to use it that way. Any help would be greatly appreciated!!
Ready to get this beast on the road. Thank you
File Type: jpeg 56CA5304-FBAF-447B-9F74-9F855634620E_1523824448384.jpeg (718.9 KB, 40 views)
File Type: jpeg B393F187-2A32-4267-B906-C52526ED7F48_1523824481701.jpeg (833.1 KB, 35 views)
File Type: jpeg 1A5748D8-03A5-4B5D-92EF-993811E2DFEF_1523824495375.jpeg (972.9 KB, 34 views)
Johnny5101 is offline
post #2 of 2 (permalink) Old 05-15-2018, 10:49 AM
MidNightRGU's Avatar
Any idea what year bike this is? Or the model?
I would not cut and splice, just in case work needs to be done in the future. I would fetch a plug and wire up everything using a service manual as a guide. Without The Manual you can use a multi tester to document the wires. BTW, the license lamp is on different circuit than the rear running lights.
Don't ride faster than your angels can fly.
MidNightRGU is offline
Roadglide overlay fender question Johnny5101 Aftermarket Accessories 3 03-26-2018 09:27 PM
bad dads fender overlay and tour pack teeboz Aftermarket Accessories 10 08-30-2015 07:34 AM
Anyone make a CVO style rear fender overlay that fits CVO taillights Steelerdude1 *General Road Glide Discussions/Pictures 7 11-06-2014 05:53 PM
Anyone use a rear fender overlay? jayfire Paint & Bodywork Section 6 01-21-2014 05:55 PM
Wire Harness audio overlay BDMastiff Aftermarket Accessories 3 08-14-2010 09:17 AM
