ABS and Clutch fluid flush - Road Glide Forums
 5Likes
  • 2 Post By 30glock
  • 3 Post By Thermodyne
post #1 of 3 (permalink) Old 04-18-2018, 08:00 AM Thread Starter
30glock's Avatar
For those needing this service done, don't believe the HD BS that the Digi-tech is needed for ABS it's complete BS. Now if by chance you introduce air into the system, then the digi-tech will be needed to bleed the system and module.
I just did this, 45 min tops flushing both clutch and ABS, total cost $10 for a bottle of DOT 4. Very simple process.
https://www.youtube.com/watch?v=_tddIQ3uuBs&t=58s
Bevis and Cdan19 like this.
30glock is offline
post #2 of 3 (permalink) Old 04-18-2018, 09:22 AM
Cdan19's Avatar
I love the ride it wrench it site. This guy is always spot on and very clear and easy to follow. Nice post.
Cdan19 is offline
post #3 of 3 (permalink) Old 04-18-2018, 12:40 PM
Thermodyne's Avatar
In this case, the guy has an incomplete understanding of the system he is working on.
While you could bleed the system if you were to say, replace a caliper. You can not properly bleed it if air is introduced above the abs unit, like when a longer brake line is added to adapt for taller bars. There will always be a risk of air entering the ABS unit as it pass the damper orifice. And as far as the fluid change service goes, that's a whole nother procedure. Its a fluid change, followed by an ABS flush procedure, and another fluid change.
The ABS unit is bypassed during normal brake operation. When in ABS function, it uses a pump, an accumulator and some valves to apply and release the brakes. During the flush procedure, it uses these same components to move fluid in and out of the system, so as to flush it.
You don't need to take it to the dealer to get it done with a DT2. You can do it with an interface and a laptop.
There is a long thread on the subject complete with valve body schematics. And a little clip of the flush being done to a rear brake.
https://www.roadglide.org/31-safety-a...failure-2.html
glide69, RGKen and ChromeSpark like this.
Thermodyne is offline
ABS flush [email protected] *General Road Glide Discussions/Pictures 6 03-31-2018 06:57 AM
Bad clutch fluid from factory? Subic97 *General Road Glide Discussions/Pictures 4 09-16-2016 09:36 AM
Dirty Clutch Fluid Q-Hog Fluids and Lubricants 15 08-19-2016 09:01 PM
2011 RGU with ABS - Brake Fluid Change Minivend Do-IT-Yourself 11 08-15-2015 05:16 PM
How often do you flush your brake fluid? jcanrun *General Road Glide Discussions/Pictures 12 05-08-2011 01:28 PM
