Changing Brake Pads - Road Glide Forums
post #1 of 6 (permalink) Old 06-03-2013, 03:58 PM Thread Starter
Changing Brake Pads
Went to change my brake pads and the manual's description sucked as usual so I found this and thought I'd share.
http://www.moccsplace.com/images/harley/brake/brake.htm
2004 Impact Blue V&H Dresser Duals V&H Slash Monster Ovals PCIII 10" Yaffe Monkey Bars Progressive 440 11"
matty3000 is offline
post #2 of 6 (permalink) Old 06-03-2013, 05:14 PM
sanding inward and outward toward the axel, NOT in a circle around the rotor.
Thank-you, learned somin new
reds4 is offline
post #3 of 6 (permalink) Old 06-03-2013, 05:44 PM
h-donut's Avatar
getting the pin out the first time was a mystery, not sure why???
but overall, very easy process, even bleeding the line with a mity vac.
2010 FLTRX- r o a d g l i d e
h-donut is offline
post #4 of 6 (permalink) Old 06-03-2013, 07:03 PM
02heritage's Avatar
Good job with the link.
2012 Maple CVO
02heritage is offline
post #5 of 6 (permalink) Old 06-11-2013, 03:24 PM
killintime's Avatar
Good info, thanks for sharing.
First prize is a Cadillac Eldorado. Second prize is a set of steak knives
killintime is offline
post #6 of 6 (permalink) Old 06-18-2013, 07:40 PM
I have never removed the caliper to replace pads. I would loosen the lid to the brake resivoir, tape a rag around it, loosen the pins then slide a putty knife between the pad and the rotor and pryed out. Pull the pins and the pads fall out new pads slip rite in.
TC308 is offline
Changing Break Pads.....HELP Nevadasun Tech Area 30 04-21-2014 10:40 AM
Follow up. Changing Rear Brake Pads..... Nevadasun Tech Area 0 02-22-2014 02:33 PM
Replacing Rear Brake Pads w/ Lyndall pads 1st Sgt Do-IT-Yourself 20 08-25-2013 04:57 PM
Changing brake pads? justincollins *General Road Glide Discussions/Pictures 7 08-24-2013 11:24 AM
Changing Brake Pads and Flush Lines.... Nevadasun *General Road Glide Discussions/Pictures 19 05-22-2013 07:27 PM
