Amsoil - Road Glide Forums
post #1 of 9 (permalink) Old 06-06-2013, 12:18 PM Thread Starter
Amsoil
Hello RG family, I was reviewing the do-it-yourself thread on servicing my bike and had a question. Is there an issue with using Amsoil 20w/50 in all three holes. If so what would be your suggestions for the tranny and primary.
mallen810 is offline
post #2 of 9 (permalink) Old 06-06-2013, 12:32 PM
tdkkart's Avatar
I think most of us will recommend something designed for transmissions in the transmission, and 80-90W or 90-140W. Amsoil has a couple of trans oils that are good, or Redline's shockproof line of products.
The primary can be most anything, and a lot of people seem to like Harley's version. Currently I use the same I use in the trans as I think the design of the current compensator can benefit from a high pressure, high shear strength oil.
tdkkart is offline
post #3 of 9 (permalink) Old 06-06-2013, 12:44 PM
X In Black's Avatar
The right oil per hole...
I've never used 20W50 in all three holes. Motor oil is different than tranmission fluid which is different than primary oil. I use the following and have for many years with no issues what so ever:
Engine- Amsoil 20W50
Trans- Redline V-Twin Transmission Oil with ShockProof
Primary- Redline V-Twin Primary Case Oil
Or any other brand you choose...
2012 FLTRX
Rinehart 2 Into 1|Ness Big Sucker AC|Andrews 57H Cams|PowerVision
X In Black is offline
post #4 of 9 (permalink) Old 06-06-2013, 12:50 PM
Fleshwound's Avatar
I just did my 1000 mi service and I used amsoil 20/50 synthetic in the engine and primary and amsoil severe gear 70/110 in the trans. Clutch and trans operation seem much better . I also used amsoil in my turbo vrod for years. I highly recommend amsoil.
2013 CANDY ORANGE cyclesmiths XL banana boards, pm shifter & brake pedals. Mean mug , Covington covers , Hawg Wired CS300 and Dx speakers.
"My bright is to slight to hold back all my dark"
Fleshwound is offline
post #5 of 9 (permalink) Old 06-06-2013, 05:46 PM
wjco9's Avatar
Amsoil 20/50 motor and primary, 75/140 in Trans, never sounded better or ran better
Live to Ride
Ride to Eat
wjco9 is offline
post #6 of 9 (permalink) Old 06-06-2013, 06:24 PM
OldNerdGuy's Avatar
I used to use Amsoil in the crankcase, until I needed some on the road and could not find it. That is why I switched to Mobil1. You can usually find that at Wally World or one of the parts chain stores.
OldNerdGuy is offline
post #7 of 9 (permalink) Old 06-06-2013, 07:09 PM
Torquey's Avatar
What you CAN do and get away with, both in life and regarding oils, is not necessarily what you SHOULD do!
Do a search on oils in this Forum!
Torquey is offline
post #8 of 9 (permalink) Old 06-06-2013, 07:30 PM
Mobil 1 V twin in the engine and Redline in the Trans and Primary. I also use the Scavenger Oil change system and a K and N oil filter with the easy off nut.
Minivend is offline
post #9 of 9 (permalink) Old 06-07-2013, 09:58 AM Thread Starter
Thanks for all your responses, I will be purchasing these items this weekend and doing my 1000 mile service next weekend. Looking forward to doing this, it will be my first time doing my own service. This site has been a big help to me.
What about Amsoil dsenger Troubleshooting for Road Glides 29 10-18-2012 01:59 PM
1,000 Service w/ Amsoil bd1980 *General Road Glide Discussions/Pictures 10 09-29-2012 12:34 AM
Anyone use AMSOIL Quickshot se ? mea4dxl ECM/Fuel Management systems 17 04-15-2011 11:34 PM
Amsoil Radioactive *General Road Glide Discussions/Pictures 11 03-02-2011 11:50 AM
Amsoil JacktheBagger General Off-Topic Discussions 22 06-25-2010 09:32 PM
