DIY "Shorty" Antenna - Road Glide Forums
 11Likes
post #1 of 11 (permalink) Old 06-07-2018, 02:57 PM Thread Starter
QNman's Avatar
I bought a tourpack, along with the quick disconnect mounting for it, and now my whip antenna is too long. I bought two separate "shorty" antennas to fit under it. One was still too long, and one (about 3" long) has TERRIBLE reception.
So, instead, I grabbed a heavy set of side/wire cutters and cut the factory down to about 6" long, and put a vacuum plug on top. It not only looks completely "factory", but the reception is still phenomenal!
Cost: $0
08Zinc, madmat, Sparky0426 and 2 others like this.
2016 FLTRXS, Stage 2 motor, Boom! Stage II audio. Black Quartz.
QNman is offline
post #2 of 11 (permalink) Old 06-07-2018, 06:32 PM
Sparky0426's Avatar
Agreed, don’t like the long whip. Did the same to mine.
2018 Ultra, Twisted Cherry
Sparky0426 is offline
post #3 of 11 (permalink) Old 06-07-2018, 08:19 PM
twowheeladdict's Avatar
I unscrewed the antenna to test fit the tour pack and haven't put it back in and don't miss it. I only listen to the music on my 32Gb micro thumb drive.
I should just get another rubber plug and plug the hole.
Gregfry likes this.
twowheeladdict is online now
post #4 of 11 (permalink) Old 06-08-2018, 09:12 AM
sfcusaret2004's Avatar
Cost: $0
without pictures, it didn't happen.
QNman and Obxrggpd like this.
sfcusaret2004 is offline
post #5 of 11 (permalink) Old 06-09-2018, 10:26 AM
Cost: $0
Glad its working for you. Keep in mind that you cut the antenna if you have problems in the future. For an antenna to work optimally, its electrical length needs to match the length of the frequency you're tuned to. The electrical length is different from the physical length. Did you notice how the wire wraps around the mast like a corkscrew? It is making a coil, which increases the electrical length. Without the correct length, you may still be able to get the stronger stations, but you'll have trouble with the weaker ones.
You didn't mention it, (and you only talked about 1 antenna) so I assume you don't have a CB radio. If you do have a CB radio, don't transmit with the antenna cut down, you'll fry your CB. Because the antenna is not the correct length, the transmit power will be reflected back into the radio and cook it.
CantRider is offline
post #6 of 11 (permalink) Old 06-11-2018, 09:27 AM Thread Starter
QNman's Avatar
I did not know that!
No, I have no CB, but that's good information for those who do!
The meat of what I'm trying to say in what I did - I bought TWO "shorty" antennas, whose wire length was (supposedly) correct, yet my manually chopped one works better than either, and it was free!
QNman is offline
post #7 of 11 (permalink) Old 06-12-2018, 05:00 PM
SteveH's Avatar
I use the following antenna on my tour pack and it screws right on -
Scosche - Replacement Antenna - 13" Mast - Model: RMA900
2017 Road Glide Ultra, Black Quartz, CD leds & flashers, Electra Glo Keystone Auxiliary LED Run/Brake/Turn Lamps, Rinehart 4.5" slip-ons, T-Bag lid covers, LRS 15" Thresher, Powder coated wheels
SteveH is offline
post #8 of 11 (permalink) Old 07-23-2018, 01:30 PM
Ibdman21's Avatar
I just did this mod, and it works good enough. Better than hearing static til my Bluetooth connects.
QNman likes this.
Ibdman21 is offline
post #9 of 11 (permalink) Old 07-23-2018, 09:33 PM
Taz_FL's Avatar
Cost: $0
I ran into the same issue, so I basically did the same thing you did, except instead of a cap I put a small skull on the end. My reception suffered but if I get somewhere I can't pick up a good station I just switch to my media.
QNman likes this.
Taz_FL is offline
post #10 of 11 (permalink) Old 07-27-2018, 05:15 AM
Bevis's Avatar
I cut mine down with a cut-off wheel. I pulled the original end off the mast, sanded the short piece into a point and pushed the oem end back on..just for good measures, used a piece of shrink warp over it too. I still get good reception, when I'm not listening to XM or off my phone.
Bevis is offline
Raptor Shorty Antenna WickedRican Audio 14 10-03-2011 11:13 AM
shorty antenna BklynRGU Road Glide Specific Discussions 1 05-22-2011 04:56 PM
shorty antenna BklynRGU Aftermarket Accessories 0 05-22-2011 12:38 PM
shorty antenna BklynRGU Road Glide Specific Discussions 7 05-15-2011 07:17 PM
Boom Audio Shorty Antenna's Wooden Nickel Road Glide Specific Discussions 3 12-12-2010 09:14 AM
