Brake noise - Road Glide Forums
 3Likes
  • 1 Post By dreeves
  • 1 Post By gman
  • 1 Post By skratch
post #1 of 10 (permalink) Old 06-11-2018, 06:34 PM Thread Starter
gman's Avatar
Brake noise
I put front and rear brakes on my 2017 FLTRXS. I bought Lyndall Racing 7254-Z PLUS for both. I am getting a noise when applying the front brakes like a chipping sound. They stop just fine and i did a couple of abs stops also no problem. Any thoughts? Thanks in advance.
gman is offline
post #2 of 10 (permalink) Old 06-11-2018, 07:00 PM
eddienelson's Avatar
Take them off and put them back on again just to make sure they are on right.
2016 RG Custom Vivid Black
eddienelson is offline
post #3 of 10 (permalink) Old 06-11-2018, 07:16 PM
Yes do that. Had the same thing happen one time and it was the little brake pad pin retainer deal. That was on a BMW but likely possible to get something off a little. Will also allow you to recheck the torques.
eddienelson likes this.
2016 Road Glide Ultra
dreeves is online now
post #4 of 10 (permalink) Old 06-16-2018, 05:47 PM Thread Starter
gman's Avatar
Was by the dealer today and they said with the after market brakes i should put some anti squeak on the backing plates. Any thoughts?
gman is offline
post #5 of 10 (permalink) Old 06-16-2018, 06:42 PM
Some do it. I didn’t have to. Never understood why you would need grease between a piston and flat surface. No noise at all from my EBC’s. Only thing I did was clean them real good before installing them.
post #6 of 10 (permalink) Old 06-17-2018, 01:10 AM
BigBlockBobby's Avatar
I've installed a lot of Lyndall Gold + pads and never had an issue. Any new shinny spots on the rotors? Are the rotors warped? Might be a good idea to setup a dial indicator to check. Might just try cleaning the rotors a bit.
BigBlockBobby is offline
post #7 of 10 (permalink) Old 06-17-2018, 08:11 AM
r_einan's Avatar
You can try blowing the brake dust out of the piston and dust boot area with compressed air, gently enough not to damage the boot, but hard enough to get in. A HD mechanic friend taught me that trick when I had a rear brake with lots of life in the pads that wouldn’t quit chirping.
RE
r_einan is offline
post #8 of 10 (permalink) Old 07-08-2018, 08:56 PM Thread Starter
gman's Avatar
Thumbs up Update
I spoke with a very nice young lady at Lydall and explained my situation. They sent me a new set of gold pads and they work outstanding no noise and brake very smoothly. I told them that they now have a customer for life.
Little Wing likes this.
gman is offline
post #9 of 10 (permalink) Old 07-09-2018, 04:30 AM
skratch's Avatar
Some do it. I didnít have to. Never understood why you would need grease between a piston and flat surface. No noise at all from my EBCís. Only thing I did was clean them real good before installing them.
because the brake pads are not tight up against the rotors, vibrations allow the pads to vibrate against the pistons. that can cause some weird harmonics and brake grease basically 'cushions' the pad to piston contact to prevent this. sometimes, you get lucky and don't need it.
Bleachey likes this.
skratch is online now
post #10 of 10 (permalink) Old 07-09-2018, 04:39 AM
Ohiobellboy's Avatar
My rear pads started making a weird noise recently. Pads have less than 1k miles on them. Pulled them off and blew the dust out. Problem solved for me.
A.K.A OBB
Ohiobellboy is offline
Valve intake noise/cam overload noise Budd559 Engine Related 9 02-15-2016 05:23 AM
Brake noise Jas5489 Troubleshooting for Road Glides 13 08-26-2015 07:22 AM
need help with brake noise veetwin Troubleshooting for Road Glides 14 03-19-2014 09:43 PM
Brake noise, should I look into this Rgc13owner Troubleshooting for Road Glides 3 08-28-2013 11:54 AM
Front brake noise? SilverGhost Troubleshooting for Road Glides 9 06-27-2012 08:41 PM
