6.5 Screen protector - Road Glide Forums
post #1 of 2 (permalink) Old 08-08-2018, 05:14 AM Thread Starter
gman's Avatar
Anyone know how to safely remove old screen protector in order to put in a new one?
gman is offline
post #2 of 2 (permalink) Old 08-09-2018, 09:57 AM
wevsspot's Avatar
Take a hair dryer or heat gun (both on lowest or medium settings) and heat up the screen protector a little bit. Then use your finger nail to grab it from one of the corners (where you can see the 45 degree cut at the outer corner edges). If you can't grab it with your finger nail, try a wooden or plastic tooth pick.
If those efforts fail, you might need to remove the radio and then the face plate of the radio to give you un-hindered access to all of the sides of the screen protector.
wevsspot is offline
6.5 screen protector smitty901 Audio 3 07-02-2018 08:06 PM
RG Vent Screen Mod with matching A/C screen lp_ *General Road Glide Discussions/Pictures 38 02-24-2018 09:20 PM
NuShield anti glare screen protector..? Rasconzo *General Road Glide Discussions/Pictures 0 06-20-2016 10:04 PM
LED Headlight protector FLTR2008Trike Lighting 2 05-07-2013 11:39 AM
