Jumper cables ? - Road Glide Forums
post #1 of 32 (permalink) Old 06-16-2013, 08:31 PM Thread Starter
caboverbob's Avatar
Jumper cables ?
So when a friend had a dead battery on his softail at work a few weeks ago and were not successful in push starting it , I found a extension cord and made jumper cables out of it to jump it from my bike. This got me thinking and today I made some cables that will work in a pinch. Basically I wanted to be able to hook up to my battery tender lead w/o having to remove the seat to get to the battery. I got some 2 conductor wire from Napa and installed 2 connectors like those on my tender lead, one to connect to my bike and one to connect to the dead bike. I also made a short lead with clips that can be connected to the longer lead if the dead bike doesn't have tender lead. Wire is 14 ga., a little light for the application, but it worked a few weeks ago and I'm sure it'll work again.
Folded up it'll tuck away neatly until its needed.
Peace
CABOVERBOB PILEDRIVERS LOCAL 34 OAKLAND, CA RIDE IT LIKE YA STOLE IT !
'01 FLTRI, T-header, Big Sucker, Terry Comp, S&S 510G, Road 6 Customs, SMW, Arc Audio, JL, Sidecar Cycles, Progressive, Race Tech, Metzeler, JHC
Build thread
caboverbob is offline
post #2 of 32 (permalink) Old 06-16-2013, 08:41 PM
eldridgetom's Avatar
I'd be headed to the patent office. Sounds pretty cool
eldridgetom is offline
post #3 of 32 (permalink) Old 06-16-2013, 08:45 PM
I have jumpers that plug into the battery tender plug. Always take them on trips.
HogPro is offline
post #4 of 32 (permalink) Old 06-19-2013, 11:23 AM
rocus's Avatar
awesome idea, I'll be making a set for myself
I am my only fear / V&H power duals / monster ovals / fuelmoto AC / PV tuner
rocus is offline
post #5 of 32 (permalink) Old 06-19-2013, 12:21 PM
TimmyG's Avatar
Been thinking about doing this for a while. But I had thought about an on and off switch in the middle.
TimmyG is offline
post #6 of 32 (permalink) Old 06-19-2013, 01:16 PM
Screamin''s Avatar
I tried this very same set-up a year or so ago. The jumper wires began to smoke and melt big time. And yes, they were connected properly. Somebody told me that too many amps were going through the thin jumpers. If it worked for you, that's great.
2009 FLTR
Screamin' is offline
post #7 of 32 (permalink) Old 06-19-2013, 01:46 PM
jimmyray11349's Avatar
I bought a set of jumper cables from Autozone...very compact, 10 gauge....10' long I think..$15 or so. Have not tried to jump start from tender...will that work?
87hp 101tq
Baggershield
Harley Hammock-Adj.Back Rest
Saddlebag Bra
Hidden Multi-Color LEDs
Jagg Fan Assisted Oil Cooler
jimmyray11349 is offline
post #8 of 32 (permalink) Old 06-19-2013, 01:49 PM Thread Starter
caboverbob's Avatar
Tender will not jump it, I only used the tender connections. Provided the dead bikes starts easily current draw can be minimal and prevent melting shit.
Peace
Build thread
post #9 of 32 (permalink) Old 06-19-2013, 02:28 PM
I started the bike I was jumping from and revved it while starting teh bike with the dead batter. The other way is to plug the tender connector into the bike that has a dead battery and use the clips on teh starter of the other bike. The bike was a softail the bike used to jump was touring. A touring battery is bigger so not sure on vice a versa.
HogPro is offline
post #10 of 32 (permalink) Old 06-23-2013, 09:10 PM
Seryoga81's Avatar
Exclamation Bad idea
We tried that with my friends bike, the wires heat up fast and produced smoke. And we didn't even jump start the other bike.
The tender wires are too thin for jump starting. Don't waste your time.
2011 Black FLTRU - I don't wash it, i ride it
Seryoga81 is offline
Handlebars that don't require new cables Mobius67 Controls & Handlebars 84 05-10-2014 02:05 PM
Battery Tender as Jumper Cable jimmyray11349 *General Road Glide Discussions/Pictures 10 10-18-2011 01:13 PM
Jumper Cables sportyguy69 *General Road Glide Discussions/Pictures 19 06-29-2011 02:28 AM
throttle cables dblkick *General Road Glide Discussions/Pictures 8 07-12-2010 11:02 AM
