M8 Clutch Fluid Bleed - Road Glide Forums
 6Likes
post #1 of 11 (permalink) Old 08-31-2018, 11:04 AM Thread Starter
Bleeding the clutch only takes a short time using the gravity method. Could have been a 10 minute job. BUT...
I couldn't get that cover off to get to the bleeder. Had to remove the right floor board to be able to remove header exhaust shields, then loosen up the header bolts and clamp bolt to give me play. Then the cover came off.
Also bled my brakes with the twin scan IV. Nice piece. Seems there is also a place in the menus to flash the head unit for after market audio. My HU is already flashed so I didn't mess with that.
2017 Hard Candy Hot Rod Red Flake M8 FLTRXS Road Glide Special. Stage III with *lots* of other goodies.
msquad is online now
post #2 of 11 (permalink) Old 08-31-2018, 11:20 AM
Jacksprat56's Avatar
Thanks for the post; didn't know such an item existed for a "relatively" reasonable cost. Appreciate the info. Just curious though, why the need to bleed the brakes,(or the clutch) on such a new bike? Thanks again.
Let us hear the conclusion of the whole matter: Fear God, and keep his commandments: for this is the whole duty of man. (Ecclesiastes 12:13)
Jacksprat56 is offline
post #3 of 11 (permalink) Old 08-31-2018, 02:02 PM Thread Starter
Manufactured date on frame is 8/16. Was on vacation this week so I got it done. Harley sent out letters to do the brake bleed every 2 years (since they use junk components and they will fail if you don't).
BTW, got a great deal on ebay. Ebay had 15% off. Eastern perf had the twin scan IV for $395. I had $45 funny money. I paid $290 out of pocket. Dealer charges $150 to bleed brakes & it will only keep going up each year. That's why I bought the device to do it myself.
Bruce00 and Jacksprat56 like this.
post #4 of 11 (permalink) Old 08-31-2018, 02:32 PM
Again, THANKS! I had the dealer do mine last summer; been miffed ever since. Considered going back to an EVO just to get away from the computers, as I am a dinosaur in this area. STILL MIGHT; go back to the EVO, that is.
I'll keep my eyes on eBay in the meantime.
post #5 of 11 (permalink) Old 08-31-2018, 02:55 PM
Bruce00's Avatar
That's a nice score, last Feb I had my brakes flush at the 4 yr mark. It was $120 at HD. Are you saying you need the tool to bleed the clutch also, or maybe I read that wrong. Anyway, I'll keep an eye on eBay for discounts
2015 RoadGlide Special
Tuned by Jamie @ Fuel Moto w/Rinehart 2>1
Bruce00 is offline
post #6 of 11 (permalink) Old 08-31-2018, 04:02 PM Thread Starter
The clutch bleed is normal. No tool needed. Was just venting at the fact that I have stock headers and had to take all that apart to get that cover off. I'd have no complaints if I replaced my headers with aftermarket. Harley could have given half and inch more of clearance and I'd be good to go.
I was "afraid" at first about doing the brakes myself. But the scan tool was VERY easy to use. Downloaded the software online. It installed very easily. Then installed the comm software. Very easy. Ran the software, found the port I was using. It was all MUCH easier than I thought it would be. I'm anal so I ran through the procedure twice, it really works over the ABS unit each time for 60 seconds.
...time to go look for a Sportster Forty-Eight Special (I like the handlebars they put on the special much better) to add the the stable. Midlife crisis time as the wife says. Haha. If I had the money I'd buy a new bike every week no matter what the occasion.
Bruce00, RGKen and Jacksprat56 like this.
post #7 of 11 (permalink) Old 08-31-2018, 04:09 PM
RGKen's Avatar
You don't need the computer to bleed the clutch but you do have to check the clutch pressure plate movement on the other side once you've bled the system. There is a minimum spec on this and if you don't get it to the spec you just re-bleed the line and keep checking until it gets to that spec. Otherwise you could have clutch drag and we all know how annoying that can be. I did the process on my 2012 CVO and wasn't aware that you had to check the clutch pressure plate and thought I was all good. Took the bike out for a ride and noticed that at every light I stopped at the bike wanted to creep forward unless I held in the brake. Mentioned it to a friend and he told me to check the clutch pressure plate movement with a dial caliper and see if it met the spec in the manual. Took me forever to find the spec but once I did mine did not meet the spec. It took 4 more bleeds to get it into spec and all was good.
2018 FLTRXS
RGKen is offline
post #8 of 11 (permalink) Old 08-31-2018, 04:26 PM
RGKen's Avatar
Really has not as much to do with the quality of Harley's components as it does the fact that brake fluid is Hydroscopic which means it absorbs moisture. It's also not just 2 years, it's every 2 years or 50k miles or if the brake fluid is tested and has too much moisture. Here is a link to a tool that you can use to check the moisture level in the brake fluid. You can find then cheaper but this is just an example.
https://www.jegs.com/i/JEGS/555/8066...cc7ad68a2becb5
Not saying this to be an a$$, more to just pass information on that many may not know. I personally don't have a problem with HD's guidelines on this as many other manufacturer's have the same or very similar standard. Just part of maintenance and I plan it into my budget.
2018 FLTRXS
RGKen is offline
post #9 of 11 (permalink) Old 08-31-2018, 06:58 PM Thread Starter
I am happy to report my clutch never felt better. It is way better now and I really wouldn't want to change the current friction point.
RGKen likes this.
post #10 of 11 (permalink) Old 08-31-2018, 07:00 PM Thread Starter
I am anal. I always err on the side of doing maintenance too soon. Just me. But thanks for the info.
M8 low transmission fluid ameleo Fluids and Lubricants 12 08-12-2019 01:19 PM
HD Fat Apes, Clutch Bleed difficulty johnnyhumble Controls & Handlebars 2 01-15-2018 03:58 AM
Low transmission fluid in M8 2016CTRoadGlide Engine Related 14 06-22-2017 02:38 PM
Who Running Platinum Bleed and Feed? SIG556 Suspensions 5 04-23-2014 05:28 PM
