Wheel Bearing Tool? - Road Glide Forums
 8Likes
post #1 of 16 (permalink) Old 09-06-2018, 04:44 PM Thread Starter
JayKS's Avatar
Wheel Bearing Tool?
Hey all,
I have a rear wheel that I bought used I'll be installing on my '17RGU this fall. I need to replace the bearings and the sleeve spacer in the process.
I was thinking of buying the Pit Posse VT102 from Amazon, but I thought I'd check with you guys to see if anyone has a wheel bearing puller/installer they'd be willing to loan or rent out. I'd be happy to pay shipping, a deposit, whatever.
Also, how about reccomendations on bearings? It's an ABS bike, of course. Stock HD? An aftermarket source?
Thanks guys. -Jay
JayKS is offline
post #2 of 16 (permalink) Old 09-06-2018, 04:59 PM
I haven't used the exact kit you're talking about but I did go look at it. It looks like a decent kit. I bought a kit from George's Garage for $200 but I use almost every week at work. As far as your bearing question; I would just get the factory ones. Easier to walk in and tell the parts person what you want and if you ever have an issue on the road, the stock bearings are always in stock.
JayKS and ia15rgs like this.
2018 FLTRXS Wicked Red
Harley Master Tech
crazy4ink is offline
post #3 of 16 (permalink) Old 09-06-2018, 05:55 PM
Brewiz's Avatar
Originally Posted by JayKS View Post
Hey all,
Thanks guys. -Jay
Don't buy it.... I bought one and tried to use it and it wouldn't pull the bearing. It's hard to describe but the way you have to hold the puller in place you have to use an open end wrench and it wouldn't hold. I sent it back and got one that TripleJ told me about. It's made by MBS manufacturing SKU WBITC-C27.
Harley Davidson Wheel Bearing Installer Puller for Twin Cam Sportster V-Rod
JayKS likes this.
Brewiz is offline
post #4 of 16 (permalink) Old 09-06-2018, 06:27 PM Thread Starter
JayKS's Avatar
Thanks Brewiz. I assume itíll do 25mm bearings as well? It only mentions 3/4 and 1Ē.
Sent from my iPhone using Tapatalk Pro
JayKS is offline
post #5 of 16 (permalink) Old 09-06-2018, 06:40 PM
Brewiz's Avatar
Jay, I would give them a call and see.
Brewiz is offline
post #6 of 16 (permalink) Old 09-06-2018, 06:46 PM Thread Starter
JayKS's Avatar
Will do. Thanks again!
Brewiz likes this.
JayKS is offline
post #7 of 16 (permalink) Old 09-06-2018, 07:11 PM
MightyWhitey's Avatar
Can’t remember what I paid. I think I found it fir $112 at tool discounters or eBay but this works well. OTC makes acceptable specialty tools. https://www.amazon.com/OTC-4790-Bear.../dp/B00BVL7YVK
Just looked at the one Brewis sent you and it will do 25mm if the stock photo is correct. It’s a common tool set.
JayKS and Stuckinnj like this.
MightyWhitey is offline
post #8 of 16 (permalink) Old 09-06-2018, 11:32 PM
JacktheBagger's Avatar
awesome , fixing to have to do mine , hhhmm the old way may still work ........ heat the hub and tap out with hammer and screwdriver or rod ..
2011 Ultra
JacktheBagger is offline
post #9 of 16 (permalink) Old 09-07-2018, 03:21 AM
kiwidave's Avatar
I bought this and I was glad I did. Works great
https://www.rockymountainatvmc.com/p...earing-Remover
To install, FREEZE bearing overnight, then gently does it with a $5 piece of threaded rod and a selection of big-ass strong flat washers .. place rod through the bearing and through the hub, then tighten the nuts at both ends of the threaded rod, on either side of hub, simultaneously.... easin' and squeezin' that bearing into place.
Or use a plastic/rubber mallet with a socket....gently...
kiwidave is offline
post #10 of 16 (permalink) Old 09-07-2018, 06:23 AM
Or if you want to make life easier for the cost of flat rate priority shipping Iíll send you my bearing tools. When youíre done send them back. Probably cost you $5 each way if I take them out of the plastic box.
Brewiz and JayKS like this.
Wheel bearing tool? TitusPollo Wheels and Tires 8 04-21-2014 04:44 PM
Steering Head Bearing Adjustment tool question 1st Sgt Tech Area 2 01-13-2014 07:41 PM
Neck bearing adjustment tool? Reddobe1 Suspensions 6 09-18-2013 06:19 PM
WTB or borrow or rent bearing tool TXcruiser Wanted! (Buy or Trade) 5 04-12-2012 09:41 PM
