Two Quickies - Road Glide Forums
post #1 of 11 (permalink) Old 09-16-2018, 11:54 AM Thread Starter
Phantom6722's Avatar
Two Quickies
Hi Guys,
Two quick questions, hope someone can help.
1, Hydraulic Clutch: What is the size and thread type of the clutch hydraulic bleed valve?
2, ABS Module: I have just done the HD recall for the ABS module on my 09 CVO. Did HD change the ABS module so it would be cleaned doing a normal brake fluid change? If so what year did this happen.
Cheers Skip
Phantom6722 is offline
post #2 of 11 (permalink) Old 09-16-2018, 12:47 PM
James's Avatar
Originally Posted by Phantom6722 View Post
Hi Guys,
#2 the recall was a fluid flush only.
James is online now
post #3 of 11 (permalink) Old 09-18-2018, 01:15 PM Thread Starter
Thanks James,
I know the recall was only fluids, just interested if HD fixed the ABS module flushing problem in later touring models.
Cheers Skip
post #4 of 11 (permalink) Old 09-18-2018, 04:24 PM
twowheeladdict's Avatar
#2. You have to open the ABS to flush the system. The dealer or buy the tool. 😞
Jacksprat56 likes this.
twowheeladdict is online now
post #5 of 11 (permalink) Old 09-18-2018, 05:24 PM
James's Avatar
Thanks James,
I see what you are saying now.
My understanding was the moco didn't educate or stress the importance of changing dot 4 fluid every two years. At some point they realized what the dirty fluid was doing to the ABS box and they updated their processes and manuals. I am not sure what year that happened, but i bet that coincides with the year cutoff on the recall.
James is online now
post #6 of 11 (permalink) Old 09-22-2018, 11:03 AM
ia15rgs's Avatar
I bought the game boy from Snap-on It also runs the abs for the bleed procedure.
ia15rgs is offline
post #7 of 11 (permalink) Old 09-22-2018, 11:26 AM
Little Wing's Avatar
to the best of my knowledge, the only thing they changed was the fluid.
it is now a synthetic hydraulic fluid. i guess it doesn't contaminate the lines as much.
i've read several articles about leaching copper from the brake system with the old fluid. (acidity?)
Little Wing is offline
post #8 of 11 (permalink) Old 09-22-2018, 01:24 PM
ia15rgs's Avatar
Syn is dot 5. You cant run dot 5 in abs as it cavatates and froths.
ia15rgs is offline
post #9 of 11 (permalink) Old 09-22-2018, 03:33 PM
it's a reformulated dot 4 called platinum label
i was under the impression that it was synthetic
https://www.harley-davidson.com/stor...12-41800770--1
post #10 of 11 (permalink) Old 09-22-2018, 03:35 PM
ia15rgs's Avatar
It still has to be changed so Im tracking its not. I can find out Monday
ia15rgs is offline
two seats, two different years! firerodder Classifieds Archive (3 months old+) 5 07-01-2012 03:16 AM
The Two Baddest Baggers in Sturgis Neano62 *General Road Glide Discussions/Pictures 23 09-28-2010 07:52 AM
Two Wheel Thunder ATrain *General Road Glide Discussions/Pictures 12 06-15-2010 01:20 PM
Help with correct Rear Shock air pressure for two up riding? zuppy51 *General Road Glide Discussions/Pictures 1 10-26-2009 10:08 PM
