hide the antennae - Road Glide Forums
 4Likes
  • 1 Post By Fillbert
  • 3 Post By Dragon Dude
post #1 of 4 (permalink) Old 09-21-2018, 12:35 PM Thread Starter
muffbrorick's Avatar
hide the antennae
so I installed a new rear fender fascia and it does not have the hole in it for the am/fm antennae. I did not want to cut holes in the new fascia so I took the antennae connector off of the mount and zip tied it to the bag mount. I ran the antennae along the frame and under the seat and zip tied it along the way with black ties. Looks clean without the antennae sticking up and it did not seem to affect the reception.
'15 FLTRXS
You can't be drunk all day if you don't start early.
muffbrorick is offline
post #2 of 4 (permalink) Old 09-21-2018, 12:53 PM
Fillbert's Avatar
I did same with the antenna even tho I still have stock fender, just didnít like seeing the antenna. Added simple hole plug, same as on the right hand fender.
muffbrorick likes this.
Fillbert is offline
post #3 of 4 (permalink) Old 09-21-2018, 02:28 PM
Dragon Dude's Avatar
I did the same mod and my reception suffered. It was OK in town but as soon as i rode out of town i started getting static and then lost the station. I ended up moving mine back to stock position.
Dragon Dude is offline
post #4 of 4 (permalink) Old 09-24-2018, 05:59 AM
I would say the reception would be partially dependent on how you mounted it. If an FM antenna is like a CB antenna there is a ground. Also you would not want the upper antenna to be grounded to the frame.
tnc110 is offline
Old Sirius Radio antennae will it work 2015 RGS bmoore951 Audio 1 11-01-2015 07:27 AM
Hidden antennae SurlyBoy Audio 28 05-22-2015 08:16 PM
Looking for short CB antennae popovdave New Members Welcome Area 13 12-08-2013 05:27 PM
Tour Pak Antennae Wiring Soonerglide Audio 16 07-13-2013 06:13 AM
Inexpensive Way to hide LED turn signals miztrz99 Lighting 6 02-13-2013 05:28 PM
