Panel mount USB in fairing? - Road Glide Forums
 2Likes
  • 2 Post By az777
post #1 of 3 (permalink) Old 10-18-2018, 12:24 PM Thread Starter
Hello all. In my 98, there was a lot of room on the fairing to install a panel-mount USB (I had one just to the inside and below each speaker). Just upgraded to a 2016 and I'm having a tough time finding a spot. There's a small area between the two gauges and the radio, but the clearance is tight. I've also consider drilling into the top of a glove box cover. Anyone found a good location? If so, can you share some pictures? If you search amazon for QIDOE and Quick Charge 3.0, you should see the device I'm trying to use (too new to post the URL).
Thanks,
BigRic
BigRic is offline
post #2 of 3 (permalink) Old 10-18-2018, 02:03 PM
It will be tough to find a good spot that still has clearance inside the fairing. The newer RGs have plastic speaker pods inside to are also part of the supporting structure for the inner and outer fairing. You want to look at mounting a USB port inside one of the gloveboxes or inside one of your saddlebags.
2018 FLTRXS Wicked Red
Harley Master Tech
crazy4ink is offline
post #3 of 3 (permalink) Old 10-18-2018, 02:06 PM
I haven't done it, but what about replacing the power port on the left side with something like the link below? You would probably have to enlarge the opening a bit.
https://www.amazon.com/dp/B07GF1CPV8...9-2f14f43f834b
koryu2u and muffbrorick like this.
2015 FLTRXS - Spookyfast bars D&D Fatcat
2009 Vivid Black FXDB PC-V D&D Fatcat
az777 is offline
Connecting ipod (playing and charging to head unit via USB and run inside fairing???? 1extremeskier Audio 6 07-28-2015 05:20 PM
Gerbing Panel Mount for Heated clothing longrides Sold 1 01-07-2014 08:16 AM
USB Charging Mount/System GRTSHRK Do-IT-Yourself 4 10-07-2012 06:52 AM
Top mount vs bottom mount in fairing? SickRick Audio 5 12-30-2011 01:28 PM
Looking for accent panel Boogitybob *General Road Glide Discussions/Pictures 13 12-08-2010 08:03 PM
