Need new battery - Road Glide Forums
 5Likes
post #1 of 16 (permalink) Old 10-23-2018, 09:26 PM Thread Starter
Need new battery
Did a quick search one notable quote I found was to be careful not to buy from eBay or amazon
Because you may get a battery that may have been sitting for too long. Buy from a large dealer that moves
A lot of product
Any advice? Ive always had good luck with yuasa. Is a AGM one worth the extra money?
I really do try and avoid the local dealer (wont comment on it) should I just get it from them ?
The factory battery lasted 7 years.
zapshd is offline
post #2 of 16 (permalink) Old 10-23-2018, 10:07 PM
TroyAK's Avatar
Need new battery
I went with a Renegade battery(600CCA) for a replacement. Been using it since May with no issues.
https://www.renegadebattery.com/Powe...Battery_2.html
2010 RGC with stage 2 and some things
TroyAK is offline
post #3 of 16 (permalink) Old 10-23-2018, 11:00 PM
An AGM battery should be better suited for the vibrations it will be subjected to in a motorcycle. The biggest problem with aftermarket batteries versus OEM batteries are the cranking amps. A lot of the time, not all of the time, but a lot of the time an aftermarket battery has less cranking amps than a stock battery. That leads to slower cranking and a shorter life for the battery.
ALMOONEY likes this.
2018 FLTRXS Wicked Red
Harley Master Tech
crazy4ink is offline
post #4 of 16 (permalink) Old 10-24-2018, 12:17 AM
https://www.techbatterysolutions.com...y-p/etx30l.htm
Just got this Friday. Works well!
geo8866 likes this.
[B]PV-Big Sucker-Rush Racing H-pipe-Big Louie's-Drago's 565 cams
Nightrain04 is offline
post #5 of 16 (permalink) Old 10-24-2018, 07:10 AM
geo8866's Avatar
Is AGM the OEM battery?
geo8866 is online now
post #6 of 16 (permalink) Old 10-24-2018, 10:40 AM
Little Wing's Avatar
i've been wondering about how the new, higher wattage starters are affected by cranking amps. any thoughts you'd like to share?
Little Wing is offline
post #7 of 16 (permalink) Old 10-24-2018, 02:10 PM
Mike U's Avatar
I have had very good luck with Battermart.com.
I have the Odyssey PC925LMJ.
Here's a link to Batterymart, if interested.
https://www.batterymart.com/
Mike U.
USMC 1975-1977
Semper Fi!
Nothing else matters!
Mike U is online now
post #8 of 16 (permalink) Old 10-24-2018, 02:55 PM
Thermodyne's Avatar
I always spend a little extra for batteries on scooters that I tour with. I bend over and buy them from the dealer, so that if it should fail out in some flyover state, I can just call the nearest dealer to deal with it.
My bar hoppers get batteries from Amazon-J&P-DK, depending who has what and at what price at the time. I bought 2 FXR batteries this year, different brands, but the exact same battery each time.
geo8866 and ALMOONEY like this.
Thermodyne is online now
post #9 of 16 (permalink) Old 10-24-2018, 04:51 PM
JakeC7R's Avatar
I am trying out a lithium ion in my Softail, 600 CCA and cranks like crazy. It's kinda spendy so time will tell if it's worth the money. I have only had it for 6 months or so, still too early to tell. Also you have to factor in a lithium ion charger/maintainer. 3 year warranty which is pretty good.
https://www.amazon.com/dp/B015RJDCCG...v_ov_lig_dp_it
JakeC7R is offline
post #10 of 16 (permalink) Old 10-24-2018, 05:33 PM
I just replaced mine with a Mega Crank AGM battery from batterymart.com. It has great reviews from other HD owners. The CCA on this battery is 420, vs the 400 on the OEM, and for practically half the price. The bike cranks and starts very well now, the original never cranked and started the bike this fast, even when new.
I can't tell you how long it will last as I just put it in a month ago, but so far so good, knock on wood.
2015 Road Glide Special
caberto is offline
Help a noob (think I need a battery) Headrope Do-IT-Yourself 17 08-22-2016 04:11 AM
Need some battery help... 2010 FLTRX *General Road Glide Discussions/Pictures 25 02-12-2016 10:01 PM
New Battery Time? MakeARunMike *General Road Glide Discussions/Pictures 4 10-30-2011 10:17 PM
New battery 2010 FLTRX Aftermarket Accessories 10 09-15-2011 07:12 PM
FREE Blackberry 8330 Curve Chargers and NEW Battery HUTMO General Off-Topic Discussions 2 12-31-2010 05:30 PM
