CVO bag lock switch. - Road Glide Forums
  • 1 Post By crazy4ink
post #1 of 8 (permalink) Old 11-12-2018, 11:16 AM Thread Starter
Good morning all. I do a lot of safety work with my bike. I'm installing flashing lights that have different patterns. My question is I'm using the lock switch like on a CVO for the luggage. It's location is on a 19 RGU right switch pod inboard position. Does anyone know where in the harness I can find the wire that would run to the tour pack and saddlebags? Would also need the color of this wire so I could pin my wire to hook into that.
I need a momentary power to change the modes of the flashing lights for different situations.
Thanks in advance.
If the Sun comes up you get another chance! Don't Worry
RGS15 Steve is offline
post #2 of 8 (permalink) Old 11-12-2018, 08:32 PM
I believe the CVO has a different wiring harness than your special. The Rushmore bikes are not direct wired like your thinking, they use canbus to control everything. So it may be difficult or you may have to wire yourself.
Buzzy is offline
post #3 of 8 (permalink) Old 11-12-2018, 09:23 PM
craigffb's Avatar
Not EVERYTHING. The comm harness for example isn't.
craigffb is offline
post #4 of 8 (permalink) Old 11-12-2018, 09:27 PM
Thanks in advance.
I have a diagram at work for the lock and unlock buttons. I use them for up and down on air ride. I’ll get it for you tomorrow.
2018 FLTRXS Wicked Red
Harley Master Tech
crazy4ink is offline
post #5 of 8 (permalink) Old 11-13-2018, 06:55 AM
Ohiobellboy's Avatar
Agree 100%.
Power locks don't run through the system either. Simple circuit.
OP, Here's another piece of eq you may want to consider. It will be cheaper, give more options and have a remote with it. I've used them before with my trucks and they work quite well. 4 buttons on it, you can program each one as a momentary of fixed switch. Small enough to hide under a cover or seat.
https://www.amazon.com/Pilot-Perform...SIN=B000BRJF62
A.K.A OBB
Ohiobellboy is offline
post #6 of 8 (permalink) Old 11-13-2018, 09:24 AM
Here is the diagram I jotted down one day and have been using it.
File Type: jpeg CF87C887-2A28-483F-AA56-6E1F81EC17BE_1542122647565.jpeg (1.03 MB, 72 views)
Harley Master Tech
post #7 of 8 (permalink) Old 11-20-2018, 08:28 PM Thread Starter
Switch harness
OK, so I have power from the outboard switch. I want to use the inboard switch to change the modes on my safety lights. not sure how to read what you have for colors.
The one you show not used is the one I want to use. It lights up so it has power when pushed but it's momentary due to the lock switch I've installed
Thanks for helping
post #8 of 8 (permalink) Old 11-26-2018, 06:41 AM
Thanks for helping
Under your left side cover, you should see a plug, near the Data Link Port that has the wire colors I'm referring to. It will have a rubber plug on it because nothing it normally plugged into it. I don't normally use the inboard switch on the right side, so I don't have the wiring colors for that one. As for the diagram that I attached, the middle switch powers the blue with white tracer that is under the left side cover and the right switch powers the blue with yellow tracer under the left side cover. the Green and Yellow above the switches refers to the Legends air suspension wiring.
RGS15 Steve likes this.
Harley Master Tech
2015 Fork lock switch removal ??? sblair *General Road Glide Discussions/Pictures 17 06-07-2017 12:20 PM
CVO Power Lock Switch griswold Wanted! (Buy or Trade) 4 04-12-2015 03:18 PM
Tour Pack Lock W/Flat Key Lock. Bill-99RG *General Road Glide Discussions/Pictures 3 01-15-2015 01:16 AM
Got my ignition switch/lock all phucked up!!!! r0de_runr Controls & Handlebars 31 09-04-2013 06:17 PM
Ignition switch lock in access? ZAKMANDO Controls & Handlebars 1 05-01-2013 02:56 PM
