2010 Road Glide Transmission Bearing - Road Glide Forums
post #1 of 2 (permalink) Old 11-12-2018, 01:17 PM Thread Starter
Rob-B's Avatar
I bought a 5000 mile 2010 FLTRX in April 2018. One problem with low mileage garage queens is - that bearings have sat unlubricated way longer than design.
The previous owner noted a "clunky" transmission and he put Red Line in it and noticed an improvement. I put another 5000 miles on it and had the 10k service done. They put HD Syn 3 in at that service.
At 11,100 miles, my transmission started making noise I thought was an inner primary bearing. Disassembly showed a scored Main Shaft eerily suggestive of lubrication failure.
So - it's all new bearings. The rest looks OK, I'm just worried about flecks of hardened steel migrating through tight clearances so I'm doing all the bearings.
The Main Shaft has the same part numbers clear through 2017. We'll hope it's a problem that is associated with prolonged storage without routine miles.
No complaints, just wanted you to know a noisy transmission might just need work, not a higher viscosity lubricant. I know the risks of buying garage queens and having to get the smooth parts working again. I often ride highway speeds in 95 degree heat in Florida and it didn't strand me. The noise just got excessive.
Rob-B is offline
post #2 of 2 (permalink) Old 11-12-2018, 06:47 PM
Sucks that you're having to go through your trans but it's good that you identified the issue easily.
2018 FLTRXS Wicked Red
Harley Master Tech
crazy4ink is offline
Transmission Bearing Failure Question Stoic Joker Do-IT-Yourself 20 12-06-2018 11:06 AM
Cracked Transmission Bearing Race @ 33,000miles kevinhd1690 *General Road Glide Discussions/Pictures 9 06-13-2014 08:36 AM
Main gear drive bearing failure 2010 RGC glideriderdave Engine Related 3 02-02-2013 06:08 PM
2009 Transmission bearing failure T-BO 399 *General Road Glide Discussions/Pictures 8 05-20-2012 08:35 AM
2010 Harley-Davidson Road Glide vs. 2010 Victory Cross Country BillyBob *General Road Glide Discussions/Pictures 6 01-05-2010 08:18 AM
