Ecu plug - Road Glide Forums
post #1 of 4 (permalink) Old 02-17-2019, 05:52 AM Thread Starter
fcm142's Avatar
Ecu plug
Good mornig all,
So question goes like this. 2017 RGS, Harley has made it so you cant have switched power from the Accessory plug under the left side cover unless you buy their switches. I have installed Show Chrome driving LEDs and ran all of the wires. The last thing I need is a switched power wire to tie into. Is there a reason why I should not buy a female 6 pin Deutsch plug and use the one pin in the data link connector that has switched power for the light switch hook up?
fcm
2017 Road Glide
fcm142 is offline
post #2 of 4 (permalink) Old 02-17-2019, 03:13 PM
What's the amp draw on the circuit you want to tie in to the plug? Data connector is generally a very low amp circuit.
DuraGlide is offline
post #3 of 4 (permalink) Old 02-17-2019, 03:44 PM Thread Starter
fcm142's Avatar
Good question. It is to power the little LED light on the switch.
fcm
2017 Road Glide
fcm142 is offline
post #4 of 4 (permalink) Old 02-17-2019, 08:42 PM
Indicator LED on a switch should be no problem unless the BCM senses it as a short to ground and opens the circuit. I'd probably try a temporary connection before I ordered the right connector and pins.
Throttle Plug Wiring Questions FLTRXS18 Controls & Handlebars 15 02-06-2019 11:44 AM
Added SENA Freewire and Harley Headset Plug bulldawgfan Audio 2 05-13-2018 07:31 AM
SE Phat Plug Wires or OEM Plug Wires wevsspot *General Road Glide Discussions/Pictures 31 07-07-2017 10:17 AM
Re-pinning the Throttle Control Actuator Plug Wires ironmark Troubleshooting for Road Glides 2 04-14-2015 07:39 PM
No Induction Module Plug Fahred ECM/Fuel Management systems 7 04-01-2013 02:06 PM
