Bolts for under triple - Road Glide Forums
post #1 of 6 (permalink) Old 02-21-2019, 02:55 PM Thread Starter
I couldn't find the info after a couple hours of reading and research. I plan on mounting a light bar to the underside of the triple but can't find what size/pitch the holes are tapped for.
2015 RGS, V&H Power Duals, Bassani 4", Self-Tuned with TR, Detatchable TourPak, Custom Halo/Switchback turn signals, Rigid 10" lightbar, B54 amp, Polk MM1 speakers, custom EQ
Stammykins is offline
post #2 of 6 (permalink) Old 02-21-2019, 05:59 PM
bucketlisthd's Avatar
Be very careful that you don't smash the light bar into the fender due to reduced clearance.
'15 Roadglide Special
'87 FXR 100"
'79 Goldwing cafe
bucketlisthd is offline
post #3 of 6 (permalink) Old 02-25-2019, 08:57 AM
MightyWhitey's Avatar
If you’re talking about the triple tree pinch bolts they’re 7/16-20 X 1 3/8
MightyWhitey is offline
post #4 of 6 (permalink) Old 02-25-2019, 11:17 AM Thread Starter
Thanks for the heads up on the clearance. Learned my lesson when I had my Vegas, the mount I used on it slid down the fork a little and pulling into an establishment the hard edge from the road to the parking lot the fender gave a nice "WACK" and thus the small chip in the top of the fender for life.
I was looking at using the bolt holes in the bottom triple clamp, in between the forks. I've found that some of the hardware on the 15 RGS is metric and some of it is standard, it looks to be about an M8, but I was hoping someone might be able to drop some knowledge on it before I start tearing into the project. Appreciate the pinch bolt info, depending on room I might have to use them instead.
post #5 of 6 (permalink) Old 02-25-2019, 06:54 PM
I’m not sure what bolt holes you’re talking about. https://shop.outpostalaska.com/OEMpa...RK_BRACKETS,/y
If it looks like an M8 it’s probably a 1/4-20 or a 1/4-28. Not much metric on that bike. Brake mounting on the front should be about it.
post #6 of 6 (permalink) Old 02-27-2019, 02:22 PM Thread Starter
Yeah, I'm special. Went assuming my triple clamp was similar to a friend's 08 SG. My lower triple clamp is hollow in the middle, if you will. Looks like I'll be bolting up to the "outer fairing skirt" bolts or the fairing mount in some way.
Determined to get the light bar on the bike, had it on my Vegas tied into the high beam circuit and it was the best mod I ever did. Turned night into day, for miles...
Loose upper triple tree bolts bless0 Suspensions 4 04-06-2016 08:33 AM
Custom Dynamics Triple Play Question?? Adamp70 Lighting 3 07-13-2015 08:36 AM
Installed Chrome bolts in the Rocker Covers ironmark *General Road Glide Discussions/Pictures 9 04-04-2012 11:19 PM
bolts in rear hub Sancho *General Road Glide Discussions/Pictures 3 01-12-2011 05:50 AM
Sheared pulley bolts Boris *General Road Glide Discussions/Pictures 7 09-02-2010 06:37 AM
