Wiring Detachable Tour Pak - Road Glide Forums
post #1 of 9 (permalink) Old 03-02-2019, 09:07 AM Thread Starter
rider17's Avatar
So, the wife one and got her "comfortable travel seat" Aka a tour pak. Put on a 17 RGS so there is no wiring or lighting to it yet. I am putting speaker pods and a CD LED light bar that will give me turn signal, run and brake on the TP. I also want to put a power port in the pack. That means a fair amount of wires that need to have QD connectors. Anyone found good connectors that aren't crazy large? I am comfortable getting the wiring connected to the bike but I can't find good connectors that aren't big old ugly things.
2017 Road Glide Special Denim Black
If the path be beautiful, let us not ask where it leads - Anatole France
rider17 is offline
post #2 of 9 (permalink) Old 03-02-2019, 10:20 AM
craigffb's Avatar
Get a connector with as meany pins in it as you need. In the long run it’s way easier to plug in one plug. My set up is a little different then what you might do, but I transferred this TP from my old bike which was a 2012.
As far as where to get the plug, eBay or amazon. Get the kit that has all the pins and sockets and you’ll probably need some extras. LOL. I also suggest a tool to crimp them. Search amazon, I can’t get it to link right now. It will save you A LOT of ass pain.
So the big plug has speakers and rear comms. The small plug on top is all the running and brake lights. The TP charging port is in line with the side marker, rear run/brake.
I’m not sure what you need to get the rear turns on your bike as I didn’t go that route so I’m not sure where you jump it under the seat.
You can see the CD rear run/brake hear as well as the side markers. If you have any questions just ask.
craigffb is online now
post #3 of 9 (permalink) Old 03-08-2019, 01:52 PM
JST JWPF connectors are fantastic micro-connectors, rated up to 3A continuous. Generally LED lights draw less than that. I can't comment on speakers, but likely less than that as well. I use them a lot for motorsport/automotive applications. They are water-resistant/proof, and can handle quite a bit of current. The 2 pin connectors are only about 0.25x0.25x0.5 in when completely assembled and connected. They are similar to deutsch DT connectors, but much smaller and molex style pin vs barrel pins.
They do require using a 2mm die crimper, i.e Engineer PA-20, readily available on amazon or your favorite online purchasing site.
Stammykins is online now
post #4 of 9 (permalink) Old 03-08-2019, 01:52 PM
And here is a link for the connectors, had to post separate because post count...
J.S.T. Mfg. Co., Ltd.
post #5 of 9 (permalink) Old 06-05-2019, 09:59 AM
MidNightRGU's Avatar
Adding a tour pack to my Ď07 I used trailer light pigtail. I also ran power plug off the running light circuit.
No pics, bikes long gone.
Don't ride faster than your angels can fly.
MidNightRGU is offline
post #6 of 9 (permalink) Old 06-05-2019, 10:25 AM
twowheeladdict's Avatar
Or you could buy everything you need right out of the Harley parts catalog.
From molex connectors to pins. everything you need to create your own custom harness that allows you to connect in without cutting a wire on the OEM harness.
twowheeladdict is offline
post #7 of 9 (permalink) Old 06-05-2019, 12:03 PM
DanHappy's Avatar
Does the factory sell a kit to do that? I didn't think they did.
DanHappy is offline
post #8 of 9 (permalink) Old 06-05-2019, 01:01 PM
Not a kit per se. You have to select the individual parts you need to make up your harness. I looked into doing it to use the Ultra tour pack on the Road King.
The parts catalog shows every part for the touring bikes, down to the connector pins.
post #9 of 9 (permalink) Old 06-05-2019, 01:13 PM
RealCowboyMD's Avatar
Looks like Bad Dad sells for $165.
https://www.baddad.com/products/part/81268
RealCowboyMD is offline
Parts! Adj Riders backrest, 16" KW,Console, Detachable Tour pack mount, Rotors magicmatt Parts for Sale 3 03-12-2015 10:21 AM
Painted Detachable Tour Pac - Passenger Seat Install Bull_Duck Paint & Bodywork Section 1 02-09-2015 01:45 PM
Help Requested - Detachable Tour Pak (Custom to Ultra) NORSEMAN *General Road Glide Discussions/Pictures 34 07-14-2013 06:04 PM
Quick detachable tour pack mount jokercraze Sold 3 08-23-2012 09:30 AM
Detachable Tour Pak musicman8120 *General Road Glide Discussions/Pictures 9 07-05-2010 02:13 PM
