Chroms Cam Cover Bolts upgrade - Road Glide Forums
post #1 of 6 (permalink) Old 04-08-2019, 09:40 PM Thread Starter
fatchoppers's Avatar
Want to swap out the stock bolts for new chromies. Can I do this without screwing up the torque pattern. I want to swap out 1 bolt at a time going clockwise . I may be overthinking this. Opinions ?
fatchoppers is offline
post #2 of 6 (permalink) Old 04-09-2019, 08:42 AM Thread Starter
I ordered bolts
post #3 of 6 (permalink) Old 04-09-2019, 11:55 AM
RFG7680's Avatar
That's how I would do it. So long as it's one at a time. I see no issue.
RFG7680 is online now
post #4 of 6 (permalink) Old 04-09-2019, 12:04 PM
craigffb's Avatar
I would pull them and replace in the torque sequences listed in the service manual if it was me. And you're gonna have to at a minimum undo the header to get at the bottom two bolts, and the front heat shield for a 3rd.
craigffb is offline
post #5 of 6 (permalink) Old 04-14-2019, 08:45 PM
WA Bull's Avatar
One for one swap is a completely acceptable way to change fasteners without disturbing the integrity of the joint. Hell we do it on Nuclear Submarines, should work here as well. Just make sure you are at final torque on the current fastener before disturbing the next one. If you want to be completely anal, after all fasteners are swapped out, do a check pass following the service manual torque pattern to verify everything is complete.
WA Bull is offline
post #6 of 6 (permalink) Old 05-15-2019, 06:39 AM
Rauzer's Avatar
^ This. I did all the chrome bolt kits on my engine this way. No leaks.
2011 Road Glide Ultra
Rauzer is offline
Side road cycles waterproof cover SGT_Rob Audio 27 02-24-2013 10:14 AM
Personal mods list (Idea from another thread) Marion Road Glide Builds-Document your builds HERE --NEW 4 04-23-2012 05:44 AM
bolts in rear hub Sancho *General Road Glide Discussions/Pictures 3 01-12-2011 05:50 AM
Sheared pulley bolts Boris *General Road Glide Discussions/Pictures 7 09-02-2010 06:37 AM
Derby Cover specs triple buzz Aftermarket Accessories 6 08-21-2010 09:13 AM
