Does this look right? - Page 2 - Road Glide Forums
 16Likes
post #11 of 39 (permalink) Old 04-22-2019, 11:59 AM
Maybe it's just me but, the placement of the front looks incorrect. I have always placed the shift rod behind the lever. It sits straighter, like in this picture.
File Type: jpg 2018-Harley-HD-CVO-Road-Glide-2018-Harley-HD-CVO-Road-Glide-High-Res_JPG-300259_18GAP_SLC_171335.jpg (327.5 KB, 94 views)
RGKen likes this.
2017 RGS - FM 124", AIM Clutch and Lightforce, 12" F47, 64m SE TB, 5.5 FI, D&D Billet Cat, Legend Axeo21 & Revo-A shocks, Trask Air Assault, Wood 408 cam, Wood directional lifters, Alloy Art Kush.
RedBlack is online now
post #12 of 39 (permalink) Old 04-22-2019, 01:57 PM
geo8866's Avatar
Mine is inside on a 17.
RGKen and RedBlack like this.
geo8866 is offline
post #13 of 39 (permalink) Old 04-22-2019, 03:52 PM
RGKen's Avatar
Like the last few guys have stated the linkage is supposed to be on the engine side up front. If the bolt touches the cylinder fins on the up shift just loosen the lock nuts at each end of the linkage and rotate it in the direction that lengthens it (makes the threaded parts longer) and this will move the front lever forward a bit and should give you the clearance you need. Then you may need to re-adjust you toe shift lever if it brings it down too much.
Jacksprat56, geo8866 and craigffb like this.
2018 FLTRXS
RGKen is online now
post #14 of 39 (permalink) Old 04-23-2019, 12:09 PM
JGray's Avatar
Mine in on the inside on the front.
2016 FLTRU Cosmic Blue Pearl
Drago's Dragula 2:1 SE Ventilator Dyno Jet Power Vision
USN Ret 1975 - 1995
JGray is offline
post #15 of 39 (permalink) Old 04-23-2019, 06:06 PM
skratch's Avatar
well, i went by the 2013 fltrxse2 parts manual, which is where i got my shifter from, and it shows the linkage on the outside.
checking the 2019 cvo road glide custom, it also has the linkage on the outside.
it's cut off on the screen captures, but i think we can all agree that it is on the outside on the rear linkage....
File Type: png Screen Shot 2019-04-23 at 6.03.15 PM.png (92.0 KB, 32 views)
File Type: png Screen Shot 2019-04-23 at 6.04.02 PM.png (87.4 KB, 30 views)
skratch is online now
post #16 of 39 (permalink) Old 04-23-2019, 06:27 PM
twowheeladdict's Avatar
Mine is on the inside (closest to the engine on the front with a spacer)
RGKen likes this.
2018 Road Glide Special, 2018 Moto Guzzi V7III Carbon, 1975 KT250 Trials
twowheeladdict is offline
post #17 of 39 (permalink) Old 04-23-2019, 06:35 PM
Originally Posted by Headrope View Post
Wife bought me a pretty part for our 2010 ’Glide. Installation was simple - too easy, really - so Im looking for reassurance:
Harley’s bar and shield linkage will end up somewhat at an angle once installed, right? And that angle won’t screw anything up over time?
Did it come with instructions?
These instructions don't look like what you did.
https://serviceinfo.harley-davidson....5?locale=en_US
post #18 of 39 (permalink) Old 04-23-2019, 06:39 PM
craigffb's Avatar
OE rod powder coated black with hem joints added. Behind on the front and in front on the back with a spacer.
craigffb is offline
post #19 of 39 (permalink) Old 04-23-2019, 07:16 PM
RGKen's Avatar
I just went to the HD website and clicked on Shop for the Bike and looked up shift linkage for a 2010 and you can scroll down on the page and click on guide and then installation instructions and there it shows it on the inside. Must have been changed somewhere along the line. Most likely will work either way but it is more in line if it is installed on the inside up front.
2018 FLTRXS
RGKen is online now
post #20 of 39 (permalink) Old 04-23-2019, 10:29 PM Thread Starter
Headrope's Avatar
Originally Posted by Thermodyne View Post
Na, that's all out of kilter.
It wont mount to the inside of the front lever?
Nope. The instructions that come with says it will, but the head of the supplied bolt disagrees. It jams against the cooling fins.
2010 Road Glide Custom, 103 big bore, other goodies.
Headrope is online now
