Broke teeth! - Road Glide Forums
post #1 of 3 (permalink) Old 04-26-2019, 01:49 PM Thread Starter
92Dinoglide's Avatar
Broke teeth!
I was attempting to adjust my clutch and was on step #2 in the manual saying to run the adjusting bolt clockwise in to let slack off...when I did so I felt a little resistance(using a 1/4 allen wench thereís resistance) turned one more twist and the teeth from the clutch hub all broke, the snap ring came out and hit me in the chest...wth happen? I would add pics but I donít know how...luckily JP has the hub for 100$ but I just got done with replacing the belt and that was 300$!!! what did I do wrong?
92Dinoglide is offline
post #2 of 3 (permalink) Old 04-26-2019, 04:30 PM
Thermodyne's Avatar
What are you working on? Not sure what you mean by teeth.
Basically, if you had the cable backed off (full short) then you turned the hub adjustment screw in till you felt light resistance, then backed off 1/2 to 3/4 of a turn, it should have been fine. Even if you didn't get the "light resistance" part exactly right, at worst it should have just released the clutch.
If you were working on a 97 or older with the snap ring holding the spring down, they can fail after service from reusing the retentions snap ring. And they usually ruin the hub when the ring pops off.
Thermodyne is offline
post #3 of 3 (permalink) Old 04-27-2019, 09:02 AM
JacktheBagger's Avatar
hubs are sintered metal , not much to them really , the EVO's , I had a couple do that ..
2011 Ultra
JacktheBagger is offline
Broke my Day Maker Bezel dinggus Lighting 13 09-18-2016 09:33 AM
Broke valve spring exracer2002 Do-IT-Yourself 3 04-19-2014 07:17 PM
Ecm broke and i had it tuned!!! OuchMMC ECM/Fuel Management systems 20 12-30-2013 03:01 AM
I broke my JACK MidniteRyder Audio 17 02-27-2013 05:57 PM
