AMSOIL in all 3 holes? - Road Glide Forums
 3Likes
post #1 of 11 (permalink) Old 06-02-2019, 09:15 PM Thread Starter
wessguffey's Avatar
I have read where people are using the 20-50 w synthetic for oil, transmission and cranny. Does anyone here use the same oil like that? Thanks.
Tomorrow is not promised, so today I choose to live.
wessguffey is offline
post #2 of 11 (permalink) Old 06-03-2019, 12:30 AM
JacktheBagger's Avatar
some do , but syn in the primary will usually slip the clutch , and syn or motor oil itself is not gear oil ..
So I use motor oil in the motor , my aftermarket clutch plates suggest light weight non synthetic motor oil , and the transmission has gears in it , so I use .............. wala gear oil ..
And after doing this all my life , I DO NOT follow the recommended fluid change ..
I change the motor and primary every oil change and the transmission , every other oil change ..
Oil is cheep ..
JtB
2011 Ultra
JacktheBagger is offline
post #3 of 11 (permalink) Old 06-03-2019, 07:28 AM
Spazz's Avatar
I run AMSOIL in all 3 holes... BUT.... SPECIFIC fluids. Amsoil sells Trans oil and Primary oil... they are separate and DIFFERENT.
Hanxno and Jeff_S like this.
RENO BAGGER AUDIO
Spazz is offline
post #4 of 11 (permalink) Old 06-06-2019, 08:17 PM
Phantom6722's Avatar
I run Amsoil but as Spazz said use motor, trans, and primary oils. I do not put motor oil in all holes.
Cheers Skip
Phantom6722 is offline
post #5 of 11 (permalink) Old 06-07-2019, 04:12 PM
woverby's Avatar
Send a message via Skype™ to woverby
Yes, i use Amsoil for all three as recommended by the dealer. I have had no problems at least yet.
2017 FLTRU
Colorado Springs, Colorado
woverby is offline
post #6 of 11 (permalink) Old 06-07-2019, 04:25 PM
smitty901's Avatar
Many do. As for SYN making clutch slip old myth that never dies. It does not. There are better option than 20/50 engine oil but not reason you can't.
smitty901 is offline
post #7 of 11 (permalink) Old 06-08-2019, 06:06 AM
Erilflynn's Avatar
My dealer is happy to pay SYN3 in all 3 holes
2019 Road Glide
2016 Street Glide Special (Gone)
2015 Kawasaki 1700 Voyager (Gone)
Erilflynn is offline
post #8 of 11 (permalink) Old 06-08-2019, 06:08 PM
Heavy Metal's Avatar
I use REDLINE all 3 holes every 5K. I'm hard on my throttle and all and when I check for metal ect a bit of dusting I see very little so I’m a happy camper. Use what you feel comfortable with.
Heavy Metal is offline
post #9 of 11 (permalink) Old 06-08-2019, 08:26 PM
I use redline in engine and trans-Harleys top oil which is a blend in primary-change all 3 every 5000 miles
diesel5 is offline
post #10 of 11 (permalink) Old 06-09-2019, 08:13 AM
geo8866's Avatar
I have tried probably 25 different combinations in the three holes, including 20/50 in all three. I'm not an expert but I feel no difference regardless of what I use and I have never had an engine or transmission issue. Next oil change I'm trying Harley's new gear oil in the tranny and primary just for the hell of it.
smitty901 likes this.
geo8866 is offline
