2015 Street Glide Special to Road Glide Special Conversion Project - Road Glide Forums
 64Likes
post #1 of 26 (permalink) Old 08-12-2019, 01:04 AM Thread Starter
Well, it has been a couple of months of planning and ordering parts. Everything was ordered from either Surdyke Hd, Newcastle HD or Intermountain HD (Utah) to include all painted parts direct from Harley. Plus exhaustive research and learning from others on this form and youtube. I converted my 2015 SGS to a 2015 Road Glide Special.
Freaky, madmat, Mike U and 3 others like this.
jm1797 is offline
post #2 of 26 (permalink) Old 08-12-2019, 01:06 AM Thread Starter
12" Klockwerks Sport Flare for Road glide
Mike U and Desert Rider AZ like this.
jm1797 is offline
post #3 of 26 (permalink) Old 08-12-2019, 01:08 AM Thread Starter
Assembling inner fairing and support bracket
jm1797 is offline
post #4 of 26 (permalink) Old 08-12-2019, 01:10 AM Thread Starter
Disassembly if batwing fairing, labelling the main harness connections to the fairing harness. Also removed gas tank, handlebars and seat to move main wire harness forward as much as possible.
jm1797 is offline
post #5 of 26 (permalink) Old 08-12-2019, 01:14 AM Thread Starter
Installed gauges into nacelle and inner fairing, installed radio, stage II amp and speakers, Harley LED headlight, 13" JSR handlebars. Handlebars were internally wired by me....tough job.
jm1797 is offline
post #6 of 26 (permalink) Old 08-12-2019, 01:23 AM Thread Starter
Outer fairing shell installed after extending the turn signal wiring. Top air duct installed too. Once everything was tightened up and double checked, I got ready to start it up. This was nerve racking but it fired up no problems. Reconnected my Ultracool reefer fan unit for oil and took it out for 100+ mile test ride. All is good!
Im really happy with the conversion. I was not a fan of the shark nose at first but they really grew on me. This is my first harley so I'm learning a lot along the way.
Freaky, Mike U, pit1600 and 4 others like this.
jm1797 is offline
post #7 of 26 (permalink) Old 08-12-2019, 01:31 AM Thread Starter
So far no error codes. The most difficult part after researching and ordering parts was the wiring extensions and routing of the wire harness. To make it easier you can buy the road glide wire harness but I reused the street glide harness and just extended some of the plugs to reach inside of the road glide fairing. Next difficult thing was internally wiring the JSR 13" handlebars. They were a bear but got them done and I love the curve they have....you should be able to see them better on below pic. Also forgot to photograph the stage II amp and speaker install. Was too excited to finish and get it to Harley for the flash...sounds 100 times better and can hear it at 60 + MPH turned up only half way.
Freaky, Mike U, Swomack and 3 others like this.
jm1797 is offline
post #8 of 26 (permalink) Old 08-12-2019, 01:42 AM Thread Starter
I have a spreadsheet that was given to me that*I built upon*to fit what I needed.... I'll see if I can upload it.
Mike U likes this.
jm1797 is offline
post #9 of 26 (permalink) Old 08-12-2019, 02:09 AM
Desert Rider AZ's Avatar
Your Street Glide definitely got a great upgrade for sure! Seems like a big project. Good job!
Mike U and jm1797 like this.
Desert Rider AZ is online now
post #10 of 26 (permalink) Old 08-12-2019, 05:45 AM
madmat's Avatar
Your bike looks fantastic jm, thanks for posting pics and notes along the way. The best-detailed swap I have seen, others will definitely use this thread that want to go down this road.
Well done, bars look killer too!
PS, welcome to the forum!
18 RGS Bonneville Salt Pearl
madmat is offline
