HELP Fuel Pump Bike wont start - Road Glide Forums
 14Likes
post #1 of 15 (permalink) Old 08-30-2019, 09:14 PM Thread Starter
I just put some 12" JSR Bad attitude Bars on my 2011 FLTRX everything went fairly smooth put everything back together and everything works but the fuel pump. Checked and rechecked wires on throttle side control. We tested and have power at run stop switch and power on both ends of the connector. I saw a similar post where the gray power wire and gray with white stripe were mixed up but that isn't it, checked fuse for fuel pump. Any Ideas guys? Thanks
graygus is offline
post #2 of 15 (permalink) Old 08-30-2019, 09:17 PM
Could be one of the pins in the connectors.
post #3 of 15 (permalink) Old 08-30-2019, 09:55 PM
FDR's RGC's Avatar
Wiring at Green plug. Recheck that connection.
FDR's RGC is online now
post #4 of 15 (permalink) Old 08-31-2019, 04:27 PM Thread Starter
Help
I eliminated the green connector still no power to fuel pump everything else functioning great?????
graygus is offline
post #5 of 15 (permalink) Old 08-31-2019, 07:00 PM
madmat's Avatar
Stupid question, did you pull the tank off while you were doing the bars?
18 RGS Bonneville Salt Pearl
madmat is offline
post #6 of 15 (permalink) Old 08-31-2019, 07:19 PM Thread Starter
No didn't pull the tank just the fairing. We have checked the run stop switch and every function works except fuel pump prime when you hit the run switch. Took all back apart and eliminated the green connector reassembled again same as the first time. I am really stumped which isn't hard lol.
madmat likes this.
graygus is offline
post #7 of 15 (permalink) Old 08-31-2019, 07:39 PM
Bruce00's Avatar
Can you run power to the pump and verify that the pump is good. Have seen electrical issues were an item took a dump while working on something completely different.
Small chance I know, but many years ago put a set of plugs in my truck, drove the truck into the garage. Installed plugs and the truck wouldn't fire....turned out the magnetic pickup in the distributor took a dump during the plug install......Go Figure! Took 2 days to figure out and never forgot the hassle
madmat likes this.
Bikeless
2015 RoadGlide Special--RIP
Tuned by Jamie @ Fuel Moto w/Rinehart 2>1
Bruce00 is offline
post #8 of 15 (permalink) Old 09-02-2019, 01:12 PM Thread Starter
Yes ran power to pump and it works also rechecked run/stop switch Not sur what's next ECM?
graygus is offline
post #9 of 15 (permalink) Old 09-02-2019, 03:06 PM
RGKen's Avatar
You said earlier that you checked the fuse, did you just look at it or did you actually check continuity with a multi-meter? Sometimes a fuse can be blown and you can't tell just by a visual and you will need to check continuity with a meter. Just touch your leads to the little silver dots on the back of the fuse without even removing it.
madmat likes this.
2018 FLTRXS
RGKen is offline
post #10 of 15 (permalink) Old 09-02-2019, 04:16 PM Thread Starter
yes we checked the continuity with meter. I noticed the power light on my power commander is not lighting thought maybe the power commander may be bad took the power commander out and tried the run/stop switch still nothing. All other functions work. We also checked continuity at run/stop switch all was normal.
RGKen likes this.
graygus is offline
