Pulling off Lower Vent door question - Road Glide Forums
post #1 of 8 (permalink) Old 06-19-2013, 10:12 AM Thread Starter
What holds the vent door on? I pulled out the one bolt and nut but seems to be hung up on the very top right corner of the door. Do you have to split the lowers to get the door off and out?
Tofast4u is offline
post #2 of 8 (permalink) Old 06-19-2013, 10:41 AM
Triplej's Avatar
That's all that holds them on. I had to twist and wiggle mine a bit to get them out.
Triplej is offline
post #3 of 8 (permalink) Old 06-19-2013, 11:36 AM
ChromeYellow67's Avatar
I took the "shelf" out of mine to get them off. There should be a slot that holds them in, just taking the center screw out wouldn't remove mine. Maybe that is because I had another piece broken, I had to replace that shelf and eyed up the assembly when I had it apart.
2015 FLHR Morocco Gold Pearl
ChromeYellow67 is offline
post #4 of 8 (permalink) Old 06-19-2013, 12:21 PM Thread Starter
I pulled the main Pivot bolt and was expecting this to like fall out. But it seem to be hung up on the top right corner of the vent if that makes sense. So you don't have to pull the top outer cover piece off? Will take another peek at it tonight.
Tofast4u is offline
post #5 of 8 (permalink) Old 06-19-2013, 12:23 PM
skratch's Avatar
actually, there is a little more to it than that. there is a slot in the top of the door that rides over a pin on the lower. you can twist and wiggle and force it out, but its easy enough to take the cap off, and remove the 3 torx screws that hold the glovebox assembly on and then just lift the door out. i do it while leaving the lowers mounted on the bike. i do have to move the lower a little bit to get the angle right for one screw, but i don't have to mess with the very bottom clamp.
skratch is offline
post #6 of 8 (permalink) Old 06-19-2013, 12:30 PM
CNMTurner's Avatar
+1.. that's the way I do it.. Good advice.
2010 FLTRX - Stage 4 SE 113 - MVA Heads, 10.5:1, SE266E cams, 58mm TB, 5.3 gr/s injectors, Polished and plated motor and trans and a few chrome extras. Fullsac DX Header and Freedom Performance Classic 4" Slip-ons. Titan II 6.5 speakers with RF PBR300x2, Monroe Airshocks
1996 Tail dragin' Fatboy
CNMTurner is offline
post #7 of 8 (permalink) Old 06-19-2013, 01:06 PM
tdkkart's Avatar
Yep, just took mine off the other day, remove the bolt, and give it a twist it'll pop off.
If you look in the back of the glove box you can see the little molded dimple that forms the pin holding the door so you'll have a little better idea of where it's at. There's alot of flex in the box and lower so a bit of pushing and pulling will get it easily.
tdkkart is offline
post #8 of 8 (permalink) Old 06-19-2013, 01:23 PM
OldNerdGuy's Avatar
I just take mine off and then dismantle it in a comfortable seated position. It is one bolt thru the hinge, but you also have to get it out of a slot that is way more accessable when you take the lid off and remove it from the bike.
Pay close attention to how the pieces come apart on the hinge. There are many parts in there to make up the racheting hinge.
OldNerdGuy is offline
Very slick garage door opener, mo-door roadie13 Aftermarket Accessories 1 03-31-2015 07:50 PM
engine dies when pulling off from stop mc glide Troubleshooting for Road Glides 6 10-11-2013 07:38 AM
Vent cover on lower rattles Kevian Aftermarket Accessories 3 07-14-2013 09:19 PM
RGU Lower adjustable sliding vent door ichiban Road Glide Specific Discussions 12 08-26-2011 04:45 AM
Getting close to pulling trigger Ran8175 *General Road Glide Discussions/Pictures 13 07-13-2011 05:21 AM
