Weird occurrence when changing battery - Road Glide Forums
 5Likes
post #1 of 13 (permalink) Old 10-14-2019, 06:02 PM Thread Starter
Cool Weird occurrence when changing battery
Hey folks, I have a good one for you.
I was removing the plastic cover on top of the battery on my 2013 Fltru. When I began to loosen the second (of 2) screws I heard a sound similar to an electronic fizzle (?) or a brief air leak. I checked all the electronics on the bike and everything os fine. Hereís the weird part, the next day there was a very small pool of oil under the bike.
I have an adjustable back rest and I thought maybe, ironically, it was leaking some hydraulic oil. But I couldnít trace any in the vicinity.
Any of you folks have any ideas before I start tearing everything down this weekend?
Related, unrelated?
Weird.
Thanks
Shark Snark is offline
post #2 of 13 (permalink) Old 10-14-2019, 07:10 PM
Related, unrelated?
Weird.
Thanks
Did you check your air shocks ?
post #3 of 13 (permalink) Old 10-14-2019, 08:10 PM
Definitely taste it before rubbing it into your eye, if its sour it's likely battery acid...if it taste like KY its not cuming from your bike, id paper test it
Big_gary and MyGlide like this.
reds4 is offline
post #4 of 13 (permalink) Old 10-14-2019, 08:21 PM
JacktheBagger's Avatar
Reds my budd , everyone been wondering about ewe ... RedBudd ??
JtB
2011 Ultra
JacktheBagger is offline
post #5 of 13 (permalink) Old 10-14-2019, 08:23 PM Thread Starter
The screw I removed was a pretty good distance from the shock but I will check the pressure. Is there some oil in the shock?
Thanks
post #6 of 13 (permalink) Old 10-14-2019, 08:25 PM Thread Starter
Yeah, some comedy. Thatís clever. It helps break the stress my friend.
post #7 of 13 (permalink) Old 10-16-2019, 01:59 PM Thread Starter
Hey Big Gary, you were right on it. The torx screw was pinching the crossover air line of the right shock. So when I backed it out the tear allowed the air, and the oil, to escape. I found the proper polyurethane tubing and will replace it all this weekend. I’ll probably shoot a small amount of light hydraulic oil in as well. Not sure I really need to though.
Thanks for the perspective!
Big_gary likes this.
post #8 of 13 (permalink) Old 10-16-2019, 02:04 PM
Hey Big Gary, you were right on it. The torx screw was pinching the crossover air line of the right shock. So when I backed it out the tear allowed the air, and the oil, to escape. I found the proper polyurethane tubing and will replace it all this weekend. Iíll probably shoot a small amount of light hydraulic oil in as well. Not sure I really need to though.
+1
Dvidal is offline
post #9 of 13 (permalink) Old 10-16-2019, 06:43 PM
Hummm...yes indeed there's oil (5wt fork oil) in the air shock for dampin, ever wonder why it's called an air line?
Shark Snark likes this.
reds4 is offline
post #10 of 13 (permalink) Old 10-16-2019, 07:00 PM
Glad to hear you got her figured out Shark.
Good to see you up & kicking Reds.
