shift linkage - Road Glide Forums
post #1 of 4 (permalink) Old 06-24-2013, 01:05 PM Thread Starter
shift linkage
parts to correct, from others post
reds4 is offline
post #2 of 4 (permalink) Old 06-25-2013, 04:34 PM
Then you still need hardware to connect the heim joint to the shifter right? Wouldn't it be easier to get one with the stud already on it like this:
http://www.ebay.com/itm/Heim-Joints-...51030768852%26
I'm still running the stock linkage. It'll probably leave me stranded any day now.
2004 Impact Blue V&H Dresser Duals V&H Slash Monster Ovals PCIII 10" Yaffe Monkey Bars Progressive 440 11"
matty3000 is offline
post #3 of 4 (permalink) Old 06-25-2013, 04:55 PM Thread Starter
front end has nut, rear threads in, hardware from ace or as this isn't anything new most good HD parts guys would have em, thinkin @ $2 hardware. Interesting that the seattle pd, ive heard have been making this since the ball and joint came out, most always the front to pop out and you wire back, drop of oil on each at oil change
reds4 is offline
post #4 of 4 (permalink) Old 07-03-2013, 03:12 PM
I just did mine and used the ones with the built in stud on the stock shift rod. . If for no better reason, then cuz you need fewer tools to change it. it does seem to shift smoother and I can find neutral easier. Why anyone would spend upwards of a c note for the same result is beyond me.
Shift linkage problem FLTRIder Troubleshooting for Road Glides 24 07-17-2015 08:35 AM
Quick and easy shift linkage mod skratch *General Road Glide Discussions/Pictures 52 02-18-2014 05:44 PM
Black Billet Flame Shift Linkage wachuko Aftermarket Accessories 19 05-02-2011 10:36 PM
Customized shift linkage ybnorml *General Road Glide Discussions/Pictures 19 03-14-2011 07:22 AM
Billet shift linkage blacktopr Aftermarket Accessories 0 03-26-2010 02:30 PM
