Need some help with wiring new bars... - Road Glide Forums
 2Likes
post #1 of 16 (permalink) Old 06-26-2013, 10:14 PM Thread Starter
Trboden's Avatar
Ok, to set things up. I have a 2012 Road Glide Ultra and I am trying to install some LA Choppers Twin Peaks 13" bars.
I would appreciate a bit of help. I have been following some pointers from a couple of threads but I must have missed something on getting the right side wires threaded in along with the TBW. I am having a heck of a time. Is there a trick to pushing one through before the other? I had the TBW threaded and had the right side controls 95% through and me lead string broke so I had to pull it back out. In the process I had to pull out the TBW because I got hung-up on the TBW.
I am giving up for the night before I get angry and rip all the wires apart and have to buy all new. I would appreciate any feedback you folks have to get me over this hump (ha a pun..get it because today is hump-day). Ok I must be too tired.
Thanks in advance...
P.S. I did not add any extensions at this point because I am only installing 13" bars and it seems like the existing wires will reach.
2017 Road Glide Ultra
Trboden is offline
post #2 of 16 (permalink) Old 06-26-2013, 10:23 PM
try using lube
Wire the throttle wires first
Remove the plastic wire wrap from the bundle
Stagger the wires from the hand controls, bunch 2-3 wires together every 2-3 inches
13FLTRX likes this.
ksarauer is offline
post #3 of 16 (permalink) Old 06-26-2013, 10:53 PM
mjsdouble's Avatar
PATIENCE, patience and then a lil more patience. Add a lot more lube as well. I had to walk away from mine quite a few times. I used weed whacked string, folded a hook with it and taped it with electrical tape in both directions. That kept it from coming loose. Hope that makes sense.
mjsdouble is offline
post #4 of 16 (permalink) Old 06-26-2013, 11:20 PM
hd4cruzin's Avatar
+1 on weed whack cord.
Sent from Motorcycle.com App
2012 FLTRX BBP
hd4cruzin is offline
post #5 of 16 (permalink) Old 06-26-2013, 11:42 PM
h-donut's Avatar
+1
other than good advice already given
on the right side my pull line broke the first time
had to step away and start the next day
2010 FLTRX- r o a d g l i d e
h-donut is offline
post #6 of 16 (permalink) Old 06-27-2013, 05:13 PM Thread Starter
Trboden's Avatar
Thanks all for the suggestions. What did you use for lube? I used some spray white lithium grease, helped but not as much as I expected.
Thanks again!
Back at it when I get home.
Trboden is offline
post #7 of 16 (permalink) Old 06-27-2013, 08:41 PM
I pulled my stock sleeve through Yaffee monkey bars, I used WD40, with a push and pull method I also cut the heated grip wire, no need for it in AZ. Just take your time and maybe some help pushing while you pull. I also used ball pull chain and that helped a lot.
Frodoe is offline
post #8 of 16 (permalink) Old 06-27-2013, 10:03 PM Thread Starter
Trboden's Avatar
Wires are pulled!
Thanks for the suggestions. Cutting off the outer plastic did the trick. Hopefully I can get everything back together tomorrow.
13FLTRX likes this.
Trboden is offline
post #9 of 16 (permalink) Old 06-28-2013, 05:04 AM
Z-SHARK's Avatar
Good news, glad you got them threw. Hope the rest of the install goes smooth.
I just finished doing my bars a few days ago.. No TBW on my bike (04)
I was so scared to try and solder wires when i started. Now i feel like a pro at it
Fill with Gas... Twist throttle... Enjoy Life
Z-SHARK is offline
post #10 of 16 (permalink) Old 06-28-2013, 07:56 AM
Dmize's Avatar
grats on the finished job.
Just adding some info in case people search.
- I used windex as a "lube" ...sprayed a generious amount into the bars at both ends
- Next time I'll cut the wires, solder in my extensions (to save messing with the plugs).
- I also cut out the green TBW plug and soldered it.
- removed the thick black HD sheathing and wrapped the wires in 2 layers of electrical tape.
D.
D.Mize
16 CVO RGU
Dmize is offline
Need Help Wiring Bars LoneCabbage Controls & Handlebars 20 05-20-2018 07:57 AM
Need help - need a tuner with some skills in SW Mich Captain America Dyno Results 1 06-02-2017 11:51 PM
Need some help on new bars stang9986 Controls & Handlebars 0 04-04-2013 08:22 AM
Need some help wiring in driving lights Ohiobellboy Lighting 1 02-23-2013 12:22 PM
I need help wiring my bars! reficul Controls & Handlebars 13 01-03-2013 08:08 PM
