ACC Switch and USB PLug - Road Glide Forums
post #1 of 34 (permalink) Old 07-08-2013, 03:52 PM Thread Starter
I believe I have the answer. But I'm looking for confirmation while I wait for the part to arrive.
I have a 2013 RGC and I want to use the Accessory switch mounted next to the Cruise control switch located between the speedo/Tach and the Radio to cut the power on/off this mod.
I want to install this in my right side glove box and connect to the accessory wiring.
I am guessing from another post that this is where I will locate the free end of the accessory plug.
Do I need to get some wiring adaptor/extension from the dealer?
2013 Road Glide Custom
2011 Fatboy *Sold*
U.S. Army Retired
hinerj is offline
post #2 of 34 (permalink) Old 07-08-2013, 03:57 PM
JayKS's Avatar
Yes, that's the plug for the Acc switch. However, I'm wondering why you'd go the trouble of routing through the Acc switch.
Why not just wire to something under the fairing that's switched on/off with the ignition (i.e. the cigarette lighter)? Seems much simpler.
JayKS is offline
post #3 of 34 (permalink) Old 07-08-2013, 04:00 PM Thread Starter
I'm not to sure how waterproof that cap is, and I am reasonable sure that the glovebox is not waterproof.
So I figure it is easier to put on switch than trying to make either of those waterproof.
Overkill maybe?
2011 Fatboy *Sold*
U.S. Army Retired
hinerj is offline
post #4 of 34 (permalink) Old 07-08-2013, 04:04 PM
JayKS's Avatar
Overkill maybe?
I think so. That cap looks pretty water resistant to me. More so than the stock cigarette lighter, which is even more exposed. That looks like a really good solution. I wouldn't hesitate to mount it in the glovebox.
JayKS is offline
post #5 of 34 (permalink) Old 07-08-2013, 08:19 PM
LegacyNoShow's Avatar
Attachment 32489
Attachment 32497
Where did you get the USB from...I gotta have one of those...nice..
2012 FLHTRU 103"/Freedom Performance duals/Cobra power port headers/Fi2000 Power Pro tuner/18" apes/Stage II Big Sucker/13" dark smoked Madstad/Gabriel air ride
LegacyNoShow is offline
post #6 of 34 (permalink) Old 07-08-2013, 08:29 PM
toogood8p's Avatar
Subscribed... More info on plug.. Please.....
Bear, Prez, Kindred MC
13 FLTRX - Candy Orange - Daymakers, Custom Dynamics - LED turn signals, Kuryakyn Scythe mirrors, Iron Aces bracket, X-grip, floor board extensions, custom sundowner seat, black KW 8", PCV, auto tune, Stage 1 AC, Drago H-pipe, 4" Dragula mufflers.
toogood8p is offline
post #7 of 34 (permalink) Old 07-08-2013, 08:37 PM
show a pic after install
and tell us where you got the parts
cool mod
ROADEAGLE is offline
post #8 of 34 (permalink) Old 07-08-2013, 11:56 PM
Candy_R3dd's Avatar
Blue Sea Dual USB Charger Socket - 2 USB Ports w/Watertight Cap
http://www.amazon.com/dp/B0082CXEI8/..._am_us?ie=UTF8
this may be a waterproof solution
Candy_R3dd is offline
post #9 of 34 (permalink) Old 07-09-2013, 07:06 AM Thread Starter
Well first thing, I had to get over the whole Goldwing verbage...but then I got it from here.
http://www.motorcycleaudioonline.com...ket-175-0.html
It is a show Chrome item, but this was the cheapest I could find.
Also...shipping was $8.XX...too me over a week before I broke down and was willing to pay that much, just seemed like so much compared to the item itself.
I will post pics once I install it. And as a previous posted advised, I will probably just run it off the same wiring from the cigarrette lighter.
2011 Fatboy *Sold*
U.S. Army Retired
hinerj is offline
post #10 of 34 (permalink) Old 07-15-2013, 08:36 AM Thread Starter
Took advantage of this rainy weekend and installed the USB Socket. (First time doing my own work, so be gentle. And Yes I know to many of you this will have been a very basic task.)
I won't detail the fairing removal as this is found in many other places and explained better than I could. (I will say that I used a utube video to give me some visual orientation.)
I started by measuring the inside of the glove box and picking the center of where I wanted the plug to sit.
I chose a spot centered left to right and so the bottom of the plug would be about 1" from the bottom of the glove box. Using a dremil I made the initial hole. I planned on enlarging it from the back and made it small enough that the overall hole could be shifted left/right, up/down if necessary.
Inside the fairing view and the side I enlarged the hole from.
Using a dremil with a cutting wheel, I just cut slots until it looked like an *.
I then got a metal file out and filed it round and to the size I wanted.
2011 Fatboy *Sold*
U.S. Army Retired
hinerj is offline
Acc switch and cig lighter dead BigB64 Troubleshooting for Road Glides 8 05-22-2015 04:06 PM
Checking if acc switch was connected at moco jacksonfdny *General Road Glide Discussions/Pictures 10 10-02-2012 06:26 AM
My ACC switch does't work ????? jacksonfdny *General Road Glide Discussions/Pictures 2 09-30-2012 12:41 PM
ACC switch question ODA CDR (RET) Controls & Handlebars 3 05-24-2012 06:40 AM
2010 ACC switch h-donut Audio 2 04-05-2011 10:21 AM
