Bugger exhaust bolts help? - Road Glide Forums
post #1 of 6 (permalink) Old 07-13-2013, 02:02 PM Thread Starter
Driftah's Avatar
Question Bugger exhaust bolts help?
Hello all,
I'm trying to replace the headers on my bike and came across some bolts that aren't budging. There are 4 of them (1 for each muffler, 1 behind the rear cylinder and 1 just under the transmission right side), the 9/16th bolts that hold the mufflers onto the headers and the headers to the frame. The look to be coated with something --I hope it's not welded or something. I've given them a pretty good go and even tapped on them with a hammer. Next step is the breaker bar but I'm worried about, well, breaking something. Are there any tips, tricks or sage advise for removing these buggers?
Many thanks,
-D
Driftah is offline
post #2 of 6 (permalink) Old 07-13-2013, 04:18 PM Thread Starter
Driftah's Avatar
Breaker bar did the trick and didn't break anything else .
Maneuvering the headers around the foot boards will be another trick... perhaps I should just take of the board on that side.
-D
Driftah is offline
post #3 of 6 (permalink) Old 07-13-2013, 05:00 PM
calgaryglide's Avatar
Take the foot board off of the rear brake side. Much easier to deal with your new header setup this way.
Highly recommend a center stand or wheel chock if you don't have a lift or motorcycle jack.
This job is easy when you follow directions of your chosen exhaust co. Be sure to check the header gaskets and torque the header nuts in the proper sequence.
After riding for a 100 miles, re check the header bolt torque cold and then re check them again after about 500 miles, again cold.
Good Luck
Troy
2019 FLTRU, Tyggr
calgaryglide is offline
post #4 of 6 (permalink) Old 07-13-2013, 05:21 PM
jim540's Avatar
Originally Posted by Driftah View Post
Hello all,
Many thanks,
-D
Heat is a wonderful thing on stuck bolts and nuts. If you don't have access to heat or don't feel comfortable using it get some good penetrating fluid and soak liberally. allow to set for 20-30 minutes and try it again.
2011 RGC, 103 engine, custom seat, Drogo's Dragula exhaust, Drago's 565 cams, ported and polished heads, HD Heavy Breather intake, Thunder Max tuner, Heritage style bars, Hawg Wired Six Pack audio system, Mean City Cycles modified seat ΜOΛΩΝ ΛΑΒΕ
jim540 is offline
post #5 of 6 (permalink) Old 07-13-2013, 06:26 PM
When I had to take mine off to get to clutch cable I used two wrenches, using second attaché to first for extra leverage, that was at frame mount and they did have lock tight on dogbone. Head I'd use care
Frodoe is offline
post #6 of 6 (permalink) Old 07-21-2013, 01:42 AM Thread Starter
Driftah's Avatar
Thanks all the words of wisdom! Got new exhaust on and about to snug everything down. Looking forward to getting her back on the road.
Driftah is offline
Check Your Exhaust Bracket Bolts! MakeARunMike Troubleshooting for Road Glides 5 08-03-2016 08:15 PM
Floor Board Bolts. Please help. KennyD104 *General Road Glide Discussions/Pictures 16 04-19-2016 07:26 PM
HELP?? Tranny bolts loosened up after long ride home!! Ma$$hole *General Road Glide Discussions/Pictures 19 07-30-2015 10:33 AM
Torq spec on exhaust head pipe bolts Dmize Intake and Exhaust 4 02-24-2013 06:53 PM
star headed bolts and Harleys ?? JacktheBagger General Off-Topic Discussions 0 05-11-2010 05:36 PM
