H-DŽ Smart Security System - Road Glide Forums
 2Likes
post #1 of 13 (permalink) Old 07-13-2013, 02:16 PM Thread Starter
OKBigD's Avatar
I bought my bike without the H-DŽ Smart Security System... Can the HD security system be installed DIY or does the dealer have to program it?
Is there any better systems out there besides the H-DŽ Smart Security System?
OKBigD is offline
post #2 of 13 (permalink) Old 07-13-2013, 02:27 PM
wjco9's Avatar
I believe they are plug and play.
Jay
Live to Ride
Ride to Eat
wjco9 is offline
post #3 of 13 (permalink) Old 07-13-2013, 02:27 PM
If you buy the Fobs and TSSM paired it's an easy DIY install, as far as other systems being better, probably so, I'll let somebody else chime in on that, I've always been happy with the HD OEM system, I installed the one on the bike I have now, might have taken 15-20 minutes.
post #4 of 13 (permalink) Old 07-13-2013, 09:23 PM
RoadGlideRider's Avatar
The installation is a DIY job. But the alarm FOBs must be paired to the system using the Harley Technician. So the motorcycle must be taken to the dealer. The Alarm was an "Active" system. That means you are required to do some kind of action to activate/deactivate the system. It was just a "Plug-N-Play" system. The newer alarm is a "Passive" alarm system. That means no action is needed to activate/deactivate the alarm. All that is needed is to walk within range with the FOB and it works. Because it is a "Passive" system, you will need to take the motorcycle to the dealer to activate the alarm.
I have had a Harley Alarm on my last and current bike. I had a 1998 Ultra. I installed it using the Retro kit. The system on my current Road Glide was installed when new. I have had different (Not Harley) systems on earlier motorcycles I have had before. In my opinion, the Harley system is the best I have had. Everything must run through the alarm. And if activated, it kills the bike. The Harley alarm is part of the wiring, not just attached or added to the wiring. Even if you cut the battery and jumper it, the bike will not run. everything, including the ignition runs through it. If alarm activate nothing will activate or run.
RoadGlideRider is offline
post #5 of 13 (permalink) Old 07-13-2013, 10:34 PM
HogWild's Avatar
'What he said ^
"No man is rich enough to buy back his past, so enjoy the moment"
HogWild is offline
post #6 of 13 (permalink) Old 07-14-2013, 06:06 AM Thread Starter
OKBigD's Avatar
Thanks for the replies. I'll probably buy the kit and install it myself. But if I have to take it to the dealer to activate the alarm, and the harley tech activates the alarm system I'm guessing it's done in the ECM? If so, is that a different process than fuel management? I just don't want them flashing my ECM and cause issues with my fuel management, the map I'm currently running is spot on......
OKBigD is offline
post #7 of 13 (permalink) Old 08-21-2018, 06:53 AM
Hi,
Did you DIY or did you take it to a dealer?
Did the dealer need to program or were the pods already programmed?
Countryriders is offline
post #8 of 13 (permalink) Old 08-21-2018, 07:07 AM
I installed mine and didn't have to take it to the dealer.
Edit....I think mine is a different type of Security System
https://www.harley-davidson.com/stor...17-6832806a--1
squirrelsnest is offline
post #9 of 13 (permalink) Old 08-21-2018, 08:44 AM
Swomack's Avatar
Read the forum thread down below
https://www.roadglide.org/29-do-your...rity-%246.html
This is the best mod going that you can do yourself
Save the money by doing this mod verse spending big $$$ on the Harley alarm
I added two of these sirens and man is it loud
Just a suggestion
Swomack
My Gallery / Click Below Link
Swomack is offline
post #10 of 13 (permalink) Old 10-11-2018, 03:10 AM
Blueangel73's Avatar
Doesn't that little $6 alarm still require the security system to be installed? I am guessing this would be alternative to the siren the HD offers in addition to the security system, correct?
Mumbling Mike
2016 Road Glide
Blueangel73 is offline
Electronic Security Alarm Flashing and Security Alarm Chirping When Ignition Switch I aklowrider Troubleshooting for Road Glides 2 05-03-2016 02:26 AM
Finding and resetting Security Codes and Bipassing Security RICKLB58 Troubleshooting for Road Glides 0 03-26-2016 09:41 AM
Smart security install BigWaterJim Troubleshooting for Road Glides 3 08-28-2015 02:02 PM
HD Security System hodgeaaco Equipment-RG 9 02-24-2012 11:03 PM
HD Smart Security System Howardsternspenis Aftermarket Accessories 7 04-20-2011 09:49 PM
