Handlebar Clamp Removal - Road Glide Forums
post #1 of 2 (permalink) Old 07-18-2013, 05:04 AM Thread Starter
jimmyray11349's Avatar
I want to add risers for my stock handlebars.
I have a service manual. I am looking at Figure 2-93 on page 2-72.
How do I remove the lower clamps? The bolts (#7) that hold the lower clamps seem to be covered with a steel plate below.
Any help would be much appreciated.
I know heritage bars are cheap but I do not want to risk ruining my grips.
87hp 101tq
Baggershield
Harley Hammock-Adj.Back Rest
Saddlebag Bra
Hidden Multi-Color LEDs
Jagg Fan Assisted Oil Cooler
jimmyray11349 is offline
post #2 of 2 (permalink) Old 07-18-2013, 05:30 AM
lostboy792's Avatar
To answer your question first. If you turn the handlebars to the left or right you will expose the bottom of the bolt head and you can get it with a long extension. However in order to put on higher risers you will not be able to do so with out cutting the top plastic piece where the clamp area is. As for getting the grips off do a search on here as there are many good ways discussed for that one. I have changed my bars three times and always reuse my grips with no problem.
2012 Road Glide Ultra, BBP. Jackpot head pipe, V&H Monster ovals, VIED's DIY rear air ride suspension, Progressive Mono Tubes in the front -1.
lostboy792 is offline
Handlebar Clamp Pin Bobinator Controls & Handlebars 5 12-13-2017 08:00 AM
1 piece handlebar clamp Jwasielczyk Parts for Sale 0 12-19-2014 07:15 AM
Handlebar Bushing removal Trak350 Paint & Bodywork Section 5 02-16-2014 09:56 AM
Single piece handlebar clamp roadglide-rider Controls & Handlebars 3 03-28-2013 09:47 AM
Handlebar removal clayman Controls & Handlebars 13 05-09-2012 10:13 AM
