CB antenna for touring - Road Glide Forums
post #1 of 3 (permalink) Old 07-19-2013, 11:25 AM Thread Starter
HUTMO's Avatar
Since I added the CVO rear fascia to my bike I had to figure out a quick easy way to mount my CB antenna for touring. I also wanted it to be easy to remove.
I decided to fabricate a mount. That would attach using the rear bolt stud on the saddle bag support. I went to Lowes and I purchased a piece of aluminum stock. it is about 1 inch wide and an eighth of an inch thick. I did not unbolt the saddle bag bolt... I just slipped the bracket on the stud and added an additional bolt. The top of the bracket (above the bolt) was bent in a 90 degree to keep the bracket from rotating on the single bolt.
I measured, drilled, bent and painted until I like the finished product. I then ran the wire which was tied up behind the saddle bag.
Simple, clean and easy. Great touring solution. Easy to remove
Gypsy Tour 2013... Get Your Kicks!
HUTMO is offline
post #2 of 3 (permalink) Old 07-20-2013, 01:51 PM Thread Starter
HUTMO's Avatar
So I took the bike out with my headset on and went cruising on the local interstate.
I started talking with a few of the truckers and they were amazed at how powerful and clear the cb was transmitting. Another item ready for the Gypsy Tour!!!
Hutmo
HUTMO is offline
post #3 of 3 (permalink) Old 04-09-2014, 11:04 PM
P2808's Avatar
I did the exact same thing however I directed my brace forward towards the front of the bike and ran the antenna out the right side hole.
P2808 is offline
Wanted: CB antenna mount jethro_3 Wanted! (Buy or Trade) 12 11-24-2013 07:34 PM
cb antenna location snarley53 Audio 3 09-18-2013 11:10 AM
J&M FPA-HJCB Flexpower In-fairing CB Antenna Tytanium Parts for Sale 5 08-22-2013 11:16 AM
Can I run NO CB antenna adown Audio 15 07-22-2013 09:09 AM
RGU Antenna relocation (CB and Radio) ksarauer Audio 3 11-07-2012 09:04 PM
