DIY - Solo Seat Mounting Upgrade - Road Glide Forums
post #1 of 3 (permalink) Old 08-22-2013, 08:05 AM Thread Starter
93-331-29psi's Avatar
I decided to do a good cleaning on the bike last night and found that the stock solo seat mounting solution on the bike leaves a lot to be desired. The plastic push nut retainers that hold the seat bolts in place are installed directly against the paint, and that solution does nothing but collect sand and dirt that has acted as an abrasive and started to wear through the clear coat. I imagine that over the course of time this will lead to that area forming rust and bubbled paint, not to mention the stock set up is oversized for no good reason at all and isn't hidden well by the seat when in a solo configuration.
I made a trip to the local hardware store to look for a workable solution, but couldn't find any suitable hardware so in true Tony style I went online and found what I needed to combat the issue and ordered what I needed in bulk quantities (couldn't get it any other way). I replaced the stock push nuts with push nuts that is half the size of stock and added a rubber washer both of which are very well concealed by the seat. I'm hoping that over time this solution will help protect the paint in that area and prevent any potential rust. issues I'll post before and after pictures tonight when I get home.
Here is a picture of the parts that were used...
93-331-29psi is offline
post #2 of 3 (permalink) Old 08-24-2013, 06:59 AM Thread Starter
Here are the pictures as promised.
Stock push nuts are easily seen with the solo seat.
With the seat removed.
The paint damage
The new rubber washer and push nut (much smaller than stock)
Finally back together and no more ugly ass white push nut
post #3 of 3 (permalink) Old 08-24-2013, 08:19 AM
Hamrhead's Avatar
solo seat
Much nicer, and very clean look. I have a solo thats just sitting in the garage......partly because I didn't like the stock parts look. I will have to give your solutionn a try.
thanks
Hamrhead is offline
Tags
solo seat mounting kit
Mounting bracket for Adjustable Rider Backrest Mounting Kit Part Number 52596-09A Oldbie Wanted! (Buy or Trade) 0 08-03-2017 09:24 PM
DIY Suction Cup Passenger Seat NS RoadRunner Do-IT-Yourself 10 08-27-2014 01:59 PM
2013 RGU DIY seat mods Gmstump41 Seating: seats, backrests 10 06-05-2014 08:55 PM
DIY Seat Biggy Seating: seats, backrests 15 02-12-2014 04:08 AM
SOLO Tour-Pak mounting HD_Shock Seating: seats, backrests 18 04-18-2011 05:55 PM
