Ignition housing - Road Glide Forums
post #1 of 4 (permalink) Old 08-30-2013, 07:48 PM Thread Starter
Candy_R3dd's Avatar
Ignition housing
I took the housing out and now when I put it all back together it works and all but it will randomly pop out! Extremely frustrating. Any help would be great!
Candy_R3dd is offline
post #2 of 4 (permalink) Old 08-30-2013, 08:36 PM
laxinharley's Avatar
YouTube "Harley ignition switch removal on street glide". He shows you how to remove and put back on. I use it every time I need to do something.
laxinharley is offline
post #3 of 4 (permalink) Old 08-30-2013, 09:55 PM
garvin90's Avatar
Its not clicked in properly. I had this happen to me two weeks ago. Put it all back in till it clicks and then reach under and feel that push button. If it isn't fully extended, jiggle it a bit. Mine got stuck so I sprayed some wd-40 and worked it in. I think they can bind since its not a part you regularly use.
Sent from the roadglide.org Monarch's phone
2012 Chrome Yella!
garvin90 is offline
post #4 of 4 (permalink) Old 08-30-2013, 11:49 PM Thread Starter
Candy_R3dd's Avatar
Thanks for responding guys, the problem was a little tricky for me. I ended up having to pop the little sticker of and tightening the torx head screw, it was loose and that's why it would wiggle loose and pop off. Headache dodged!
Ignition switch out housing removal rsscoggins Controls & Handlebars 0 02-17-2015 06:37 PM
painting switch housing gja Controls & Handlebars 14 04-14-2011 06:51 PM
Indicator Lamp Housing Question jimmyo79 *General Road Glide Discussions/Pictures 2 12-31-2010 01:39 PM
Control switch housing and switches for 2008 fern5407 Classifieds Archive (3 months old+) 0 04-04-2010 07:15 PM
Clutch cable clip on side of gauge housing GizmoGlide *General Road Glide Discussions/Pictures 8 03-26-2010 12:00 PM
