Get rid of the Tour Pak liner light pockets - Road Glide Forums
post #1 of 5 (permalink) Old 09-01-2013, 09:29 AM Thread Starter
adown's Avatar
I removed the antennas from my Road Glide and don't have the wrap around lights. I wanted the space those pockets took up, but didn't want to look for or buy a new liner.
1. Cut and remove the flat surfaces as shown in red.
2. Make a single cut along the bottom radius of the pocket.
3. Cut down the center of the biggest protrusion, top to bottom(shown in blue).
4. Use a heat gun to bend all protrusions outward, and a flat screwdriver to remove the crease(when liner is hot).
5. I used cardboard to keep the shape while fiberglassing.
6. scuff up the surface with 60 grit sand paper(just a little bit).
7. Coat the surface with resin, and put two layers of fiberglass cloth.
8. Use just enough resin to saturate the cloth.
9. Sand the surface lightly to remove high spots and sharpies.
10. Use a razor blade to remove any high edges on the inside of the liner.
11. Cut grey felt to fit the cuts inside, and use rubber cement to glue down.
adown is offline
post #2 of 5 (permalink) Old 09-01-2013, 09:31 AM Thread Starter
adown's Avatar
Here is the finished corner.
adown is offline
post #3 of 5 (permalink) Old 09-02-2013, 07:47 AM
teejay's Avatar
Well done.
tj
teejay is offline
post #4 of 5 (permalink) Old 09-02-2013, 10:10 AM
Grind's Avatar
Thanks for my project for the day.
2011 FLTRU Merlot Sunglo
CFRs, gilded pinstripes, Medallion Classic gauges
Grind is offline
post #5 of 5 (permalink) Old 09-02-2013, 10:13 AM
JayKS's Avatar
Brilliant!
Once I round up the materials, I'm definitely doing this.
JayKS is offline
Looking to get rid of taillight bar Gonekat Aftermarket Accessories 7 04-20-2014 10:51 AM
Got rid of the glide, now to get rid of these seats! justincollins Parts for Sale 8 06-09-2013 09:45 PM
Any one have a tall stock windshield they want to get rid of garzajr676 Windshields 3 04-24-2013 08:40 PM
Parts to get rid of lldsilver41 Classifieds Archive (3 months old+) 0 04-14-2012 08:42 AM
Looking to get rid of my stock dash lowdog Aftermarket Accessories 12 03-06-2011 10:49 PM
