Is it ok to disconnect the battery ? - Road Glide Forums
post #1 of 6 (permalink) Old 09-01-2013, 09:47 AM Thread Starter
rob883's Avatar
I want to run some extra power up to my fairing.I want to come off the battery for it.Is there any harm in unhooking the wires from the battery ?
1969 XLCH sold 1972 XLH sold 2002 Dyna Defender
2002 Ultra Electra Glide sold 2013 RoadGlide Ultra
1986 FXRD great bike !!
rob883 is offline
post #2 of 6 (permalink) Old 09-01-2013, 10:16 AM
It should be no worse than changing the battery. You'd have to disconnect the battery terminals in order to remove the battery which would mean theres no power to any of the wires on the bike.
post #3 of 6 (permalink) Old 09-01-2013, 10:20 AM
r0de_runr's Avatar
If you have the alarm siren, turn ignition on with fob present, then pull the maxi fuse to disable the alarm. Then you can disconnect battery.
Also, make sure you fuse the wire you install as close to the battery as possible.
r0de_runr is offline
post #4 of 6 (permalink) Old 09-02-2013, 05:36 PM
Psycho's Avatar
No problem at all, I remove my battery for the long winter months. Allways disconnect the negative terminal first!
2009 Road Glide/Red Hot - Denim
Psycho is offline
post #5 of 6 (permalink) Old 09-02-2013, 07:59 PM
As Psycho said, neg 1st, good ins when removing fairin, inline fuse any n all when going direct to batt
reds4 is offline
post #6 of 6 (permalink) Old 09-02-2013, 08:02 PM
Torquey's Avatar
The manual just about tells you to disconnect the battery before inflating the tires!
Torquey is offline
Tour park quick disconnect bikerglasses Seating: seats, backrests 8 03-18-2013 01:39 AM
Lower Fairing Quick Disconnect Kit Yesca Equipment-RG 13 07-23-2012 06:15 AM
Tourpack Speaker Quick Disconnect Options Illiniroads Audio 5 03-06-2012 09:36 PM
RGU Hard bag locking quick disconnect problem ichiban Road Glide Specific Discussions 14 10-10-2010 08:45 PM
