Need info before spending money - Road Glide Forums
post #1 of 6 (permalink) Old 09-01-2013, 03:18 PM Thread Starter
Mickeyv's Avatar
I need a luggage rack for my 2013 rg. But I would like to pick up a used tour pac later. The q is . If I pick up a 2 up tour pack mount. can i use it with my sissy bar for now. Or do I need to spend the money on a luggage rack. I like the clean look. The only time it will b on the bike when iam on a road trip. Thanks
Mickeyv is offline
post #2 of 6 (permalink) Old 09-01-2013, 06:21 PM
quikcarl61's Avatar
If you get the quick detach kit for it you could, could switch it up at will.
quikcarl61 is offline
post #3 of 6 (permalink) Old 09-01-2013, 06:46 PM
spokanebagfan's Avatar
No because the 2up mount fits in the same place as your quick release to mount would.
spokanebagfan is offline
post #4 of 6 (permalink) Old 09-09-2013, 05:10 PM
sj01fltri's Avatar
make sure you know what year the tour pac fits they changed the way the pac mounts to the luggage rack you can use a pre 09 tour pac on a 09 and later rack by making a 1/4 thick alumin sub plate with the correct hole pattern in it,i have done two already for friends
sj01fltri is offline
post #5 of 6 (permalink) Old 09-09-2013, 05:51 PM
skratch's Avatar
i think you misunderstood. he wants to use the tourpak mount as his luggage rack.
yes, you can do that. several have done it. it isn't the most elegant solution, but if you're gonna bungee a duffle bag or some sort of luggage to it, it'll work fine.
skratch is offline
post #6 of 6 (permalink) Old 09-11-2013, 04:15 PM Thread Starter
Mickeyv's Avatar
Cool Thanks
Thsnks for the help. I have pick up a tour pack mount. It works very good as a luggage rage. I think it even looks good. Later on I'll pick up the PAC. It was a lot cheaper then a luggage rack to . Saving money is a good thing
Mickeyv is offline
Vinyl or some other cheap way to see some designs before spending the $$'s on paint Mikie Paint & Bodywork Section 0 07-24-2015 09:26 AM
Holy cow need info before 5 o'clock 13HDGLIDE Tech Area 11 06-04-2013 09:27 PM
New shark owner and cant stop spending money breiss13 *General Road Glide Discussions/Pictures 28 04-04-2012 10:36 PM
