rear brakes - Road Glide Forums
post #1 of 23 (permalink) Old 09-08-2013, 04:23 PM Thread Starter
sj01fltri's Avatar
rear brakes
Hats off to the MoCo for redsigning the rear brake caliper,putting rear pads on are a snap,this is the second thing that i have found to be easier to replace than om my 01 RG,the first was the gas tank
sj01fltri is offline
post #2 of 23 (permalink) Old 09-08-2013, 04:28 PM
I did my front and rear brakes, it took me longer to loosen the bolts than anything else, extremely easy. I couldn't see paying somebody to do it.
Sent from my SPH-L710
post #3 of 23 (permalink) Old 09-08-2013, 05:47 PM
Is there anything special that needs to be done due to the ABS?
Minivend is offline
post #4 of 23 (permalink) Old 09-08-2013, 06:24 PM
r0de_runr's Avatar
Nope.
Just make sure if you pull the axle, you get the abs pickup back in the right spot and the wire is safe from damage.
r0de_runr is offline
post #5 of 23 (permalink) Old 09-08-2013, 07:10 PM
I dont think it could get easier really. Just did my rears today and took me about 15mins.
post #6 of 23 (permalink) Old 09-08-2013, 07:58 PM
Dmize's Avatar
Originally Posted by r0de_runr View Post
Nope.
never changed my brakes... am I guessing from your post correctly that you have to remove the front tire to replace the front pads?
D.
D.Mize
16 CVO RGU
Dmize is offline
post #7 of 23 (permalink) Old 09-08-2013, 08:22 PM
r0de_runr's Avatar
I always inspect and replace in conjunction with tire replacement. Don't know if you can replace pads with the wheel mounted.
post #8 of 23 (permalink) Old 09-09-2013, 04:59 AM
Ohiobellboy's Avatar
D.
I had to remove one of my front calipers to get my front wheel off to take it in for a tire change. For those with single disc brakes it should be easier. You can take the caliper off with 2 bolts. Not that big of an issue.
A.K.A OBB
Ohiobellboy is offline
post #9 of 23 (permalink) Old 09-09-2013, 05:06 PM Thread Starter
sj01fltri's Avatar
Dont think you have to remove the front tire to replace the pads just take care working the caliper out around the fender
post #10 of 23 (permalink) Old 09-09-2013, 05:59 PM
it's a trick, but the tire stays on, some jack the frame up some but not nec
reds4 is offline
Rear brakes harleyrick2003 Tech Area 6 08-03-2014 07:34 PM
Rear brakes worn out 14k. Hot rotor seahoch Troubleshooting for Road Glides 11 04-06-2014 12:30 PM
Stunt bike rear brakes throttles&triggers General Off-Topic Discussions 3 01-26-2014 08:49 PM
Tire change = no rear brakes exammo Troubleshooting for Road Glides 11 10-12-2012 04:11 PM
7mm 12 point socket for rear brakes?? Kobrak *General Road Glide Discussions/Pictures 7 04-02-2011 10:29 AM
