Header bolt torque - Road Glide Forums
post #1 of 4 (permalink) Old 09-15-2013, 04:25 PM Thread Starter
jchar27's Avatar
Header bolt torque
Does anyone know what the torque spec's are for header bolts? Help is appreciated. Thanks!
jchar27 is offline
post #2 of 4 (permalink) Old 09-15-2013, 04:58 PM
This is for my 01 not sure on the newer so you may want to verify
Tighten the top nut of the front cylinder head
exhaust flange to 9-18 in-lbs (1-2 Nm).
lower nut to 120 in-lbs (14 Nm). Final tighten the
top nut to 120 in-lbs (14 Nm).
Repeat on the exhaust flange nuts of the
rear cylinder.
Eagle
Eagle is offline
post #3 of 4 (permalink) Old 09-15-2013, 06:21 PM
This is what the values are on my '08 also. But, NOTICE::::: INCH lbs. NOT Ft. lbs.
xshovelfreak is offline
post #4 of 4 (permalink) Old 09-15-2013, 06:42 PM Thread Starter
jchar27's Avatar
Thanks Guys, much appreciated.
jchar27 is offline
Confirm swingarm bolt torque...ASAP Twistedlizard720 *General Road Glide Discussions/Pictures 19 10-22-2012 12:01 AM
Shock Bolt Torque for 2012 RGC SIG556 Suspensions 2 09-20-2012 07:00 PM
xmsn cover bolt torque SKULLZ *General Road Glide Discussions/Pictures 4 06-17-2012 09:50 AM
Exhaust header Torque Specs Buduh Intake and Exhaust 3 03-16-2012 06:01 AM
