STONED and replaced - Road Glide Forums
post #1 of 10 (permalink) Old 10-02-2013, 08:55 PM Thread Starter
STONED and replaced
When the last time you checked your Drive Belt/Transmission Sprocket Wear?
Could your replace it yourself? Is there a Thread how to?
This one was replaced for good measures, thru hole, pushed little chip thru.
the next pic's are of current belt, the upside, little damage from chip rock setting in the tranny/sprocket space.
reds4 is offline
post #2 of 10 (permalink) Old 10-02-2013, 08:57 PM Thread Starter
over 60k since removal rock found in that void area
reds4 is offline
post #3 of 10 (permalink) Old 10-02-2013, 08:58 PM
Never had a problem with my belts but...I have been both stoned and replaced........The devil made me do it!
Singlebeam is offline
post #4 of 10 (permalink) Old 10-03-2013, 07:23 AM
skratch's Avatar
I could change it myself, but I have never had to. don't know that I would though. it's a pretty intensive job. the swingarm has to be removed to change it.
skratch is offline
post #5 of 10 (permalink) Old 10-03-2013, 09:43 AM Thread Starter
Understand, If devils not laying in wait It be laughing with ya
reds4 is offline
post #6 of 10 (permalink) Old 10-03-2013, 09:54 AM Thread Starter
Looking to see if a Photo thread of how to would be of interest. No matter
Old rider asked if do his, cause of the $$$$ for a real shop to do it
Anyways Everybody should be aware to check for debri in on & @, those stone gaurds, for not being worth a $hit, can cause damage itself.
Constructiion Zones, Chip Seal areas, the logging roads (a least we're fond of) Field Parties in the Rain (we're fond of) or sometimes the wind blowing lillte meanies down the road
reds4 is offline
post #7 of 10 (permalink) Old 10-03-2013, 01:11 PM
skratch's Avatar
just cause I said I probably wouldn't do it, doesn't mean that I wouldn't like to see a photo thread doing it...
skratch is offline
post #8 of 10 (permalink) Old 10-03-2013, 02:01 PM
Ugly Shawn's Avatar
If the rock ran through in the middle and not the edge, I would run it and not worry unless you are out doing wheelies or something. I too have been stoned and replaced.
Ugly Shawn is offline
post #9 of 10 (permalink) Old 10-03-2013, 02:31 PM Thread Starter
Agreed Ugly, that top pic was a skake your head and do it, but not a the tune of 500+parts, even replacing stoned or should say check belt, sometime the tap will give it away. the pully are $$ have filled and plated a few oh and ck the pully with your fingers, you get cut the belts likely being cut..just friendly
reds4 is offline
post #10 of 10 (permalink) Old 10-03-2013, 03:03 PM
sj01fltri's Avatar
My wifes low rider had two poke thru holes in th middle of the belt at about 30,000 miles ,finally replaced it at 65,000 miles but it still wasnt broken,and yes the average wrench can do it, i did hers and the one on my 01 RG after it broke,replaced it with a belt for side car use,it was a heavy duty belt,got it from HD,helps to have some special tools,like front pulley socket,made my own,and the tool that holds the sprocket from turning if you dont have an impact wrench.
sj01fltri is offline
Replaced Fuel Filter MakeARunMike ECM/Fuel Management systems 9 07-29-2012 02:17 PM
While I was getting my voltage regulator replaced.... BigDeez *General Road Glide Discussions/Pictures 16 06-26-2012 06:25 PM
Replaced my handlebars now my throttle sticks jiggydogo Controls & Handlebars 8 09-18-2011 01:11 PM
Bearings wore and Races replaced! Neano62 *General Road Glide Discussions/Pictures 8 04-11-2011 04:51 PM
Front tire replaced under warranty!(09's) motodrummer *General Road Glide Discussions/Pictures 8 07-11-2010 05:18 PM
