Fuel pump removal tool - Road Glide Forums
post #1 of 31 (permalink) Old 10-05-2013, 02:21 AM Thread Starter
I seem to remember from youtube that there is a special tool you need to remove the lock ring off the gas tank to get the fuel pump out. Anybody have the down-low on where to get that tool?
I never saw a wild thing feel sorry for itself.--DH Lawerence
Tackdriver is offline
post #2 of 31 (permalink) Old 10-05-2013, 04:28 AM
HellInABucket's Avatar
Scroll down about 3/4: http://www.georges-garage.com/chassis_tools.htm
Or... Just found this Snap-On tool, 1/2 the price: http://buy1.snapon.com/catalog/item....re&dir=catalog
2020 FLTRK
Roll away the dew...
HellInABucket is offline
post #3 of 31 (permalink) Old 10-05-2013, 12:34 PM
I use the Snap-on tool. It works great and is made of plastic so it won't scratch your fuel tank if you slip. The metal tool cost more and if you slip it can cause paint damage to the tank. Some just use a hammer and a screw driver but than if you slip.
post #4 of 31 (permalink) Old 10-05-2013, 12:56 PM
faststan's Avatar
I have this one from George's. One made from plastic or nylon would be best. JMO.
11 FLTRU 103 Red Hot Sunglow
faststan is offline
post #5 of 31 (permalink) Old 10-05-2013, 02:46 PM
Mike U's Avatar
Being very careful, I used a large flat screw driver and a hammer.
Worked fine.
Hope this helps.
Mike U.
USMC 1975-1977
Semper Fi!
Nothing else matters!
Mike U is online now
post #6 of 31 (permalink) Old 10-05-2013, 04:57 PM
Subscribing to this thread, I'm changing tanks when I have my bike painted.
Sent from my SPH-L710
dbell66253 is online now
post #7 of 31 (permalink) Old 10-05-2013, 08:19 PM
firefront's Avatar
+1 on the snapon tool. Made the job way easier. Did my bike and a friends limited in less than a 1/2 hour. From my view putting the lock ring back on would be the difficult part with any other tool.
2013 RGU
firefront is offline
post #8 of 31 (permalink) Old 10-05-2013, 09:46 PM
So you use the tool for removal and install?
post #9 of 31 (permalink) Old 10-06-2013, 09:38 AM
OldNerdGuy's Avatar
My special tool is a 1 foot section of 1" Schedule 40 PVC Pipe and a Dead Blow hammer. Works great. You do want to get in there and change the fuel filter a bit more often than I did...
This one has 50,000 miles on it. Can you guess which one is the old one and which one is the new one?
OldNerdGuy is offline
post #10 of 31 (permalink) Old 10-06-2013, 10:42 AM
Yep the tool work for removal and installation.
Sprocket Nut Removal Tool hoosierboarder Parts for Sale 0 07-31-2017 05:49 AM
Cam bearing removal/installation tool BigNorm Tech Area 5 09-01-2014 09:10 PM
Fuel Moto 107" hi output R&D motor 151Hp Pump Fuel fuelmoto Dyno Results 5 01-22-2014 07:24 PM
Cam removal tool rental? jcmer22 Engine Related 5 07-27-2012 08:03 AM
Fuel pump wanted Speedychp61 Classifieds Archive (3 months old+) 0 11-21-2010 09:02 PM
